can someone tell me what this part is
Old 26-09-2006, 08:55 PM
xrchris
xrchris's Avatar
Default can someone tell me what this part is
its on my ofac loomed rst. tried to figure it out but not sure and found a few pics of other peoples cars and couldnt even see it.
btw i've got an escort xr3i with fezzy rst lump etc put in it so bits might be in the wrong place lol
cheers chris
Old 26-09-2006, 09:37 PM
sy16v
sy16v's Avatar
Looks like the distributor cap but not sure
Old 26-09-2006, 09:48 PM
xrchris
xrchris's Avatar
should have been a bit more specific need to know what the grey thing is with the one wire coming out of it. sitting on top of the coil pack.
Old 26-09-2006, 10:06 PM
daveselwood
daveselwood's Avatar
Default grey thing
it could be a supressor
Old 26-09-2006, 10:11 PM
Chrissy_bwoy
Chrissy_bwoy's Avatar
it is a supressor, takes out ignition noise etc
AFAIK
Old 26-09-2006, 11:11 PM
xrchris
xrchris's Avatar
i was thinking it could possibly be that but werent they only fitted to ofab cars?
Old 26-09-2006, 11:13 PM
©hatter Box
©hatter Box's Avatar
Default Re: grey thing
ur right
Old 27-09-2006, 12:39 AM
xrchris
xrchris's Avatar
right so i know these supressors were fitted to ofab cars to stop interferance from the ht's effecting the map sensor signal. my cars ofac so is it possible that this is having an adverse effect?
were these supressors fitted to xr3i's?
chris
Old 27-09-2006, 01:57 PM
Chrissy_bwoy
supressors are fitted to most coilpack equipped cars
try unplugging it and see what happens
Old 27-09-2006, 02:30 PM
xrchris
xrchris's Avatar
yeah tried unplugging it and nothing. thinking about it cant really see it having an adverse effect but the cars driving me nuts with the not running right
Old 27-09-2006, 07:11 PM
Chrissy_bwoy
id look elsewhere then matey
tried the map sensor? checked for air leaks?
Old 27-09-2006, 10:30 PM
xrchris
xrchris's Avatar
no air leaks and not convinced on map sensor yet. ordered one off ebay but it was faulty
idles really poorly intermittantly then holds back now and again. idle speed control valve is ok for poor idle and starting to think ecu is a at fault for holding back and jerking
Old 27-09-2006, 10:51 PM
daveselwood
Default e
look at your pipes for cracks or splits mine ticked over like a bag of nails and smoked and wouldnt boost over 5 psi because a small diameter pipe had poped off on the boost guage
Old 28-09-2006, 12:41 AM
xrchris
xrchris's Avatar
all the pipes and that are ok. really puzzling problem not helped by the fact that its intermittant
gambo08
04-02-2016 10:49 PM
07-10-2015 12:56 PM
01-10-2015 02:00 PM
fordrallycar
30-09-2015 07:57 PM
Fordmad!
29-09-2015 07:03 PM
Quick Reply: can someone tell me what this part is
