help..wont pull, revs up ok on tickover but wont pull.
Old 29-05-2006, 09:24 AM
davsmith64
davsmith64's Avatar
Default help..wont pull, revs up ok on tickover but wont pull.
my problem is,,, the car starts and tick over perfectly, it revs perfectly..
but when i try to set off in the car it wont pull away,, keeps trying to stall,,, its as tho any preasure on the engine it tries to die... so i dont know what my problem is,, maybe the map sensor???
ALSO I AM RUNNING OFAB MANAGEMENT.
Old 31-05-2006, 01:02 PM
Rick
Rick's Avatar
map sensor would defo cause that.
Old 02-06-2006, 09:41 PM
choppa
choppa's Avatar
2 of my friends have approached me with this problem and it turned out to be a timing problem. if you can get ya hands on a flash gun, check it. disconnect the vacuum hose and put the flash gun across plug1 an flash it down to the bottom pulley. check it at idle and at 2000rpm. any workshop manual should tell you how to do it and what the degrees should be. hope it helps!
timsrs
13-11-2018 11:48 AM
tankybaby66
06-02-2016 02:24 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
wheelwizardrefurbs
22-09-2015 05:45 PM
Quick Reply: help..wont pull, revs up ok on tickover but wont pull.
