zetec mk4 1999 engine swap???
Hi there, my g/f's fiesta 1.25 zetec just snapped its timin belt, engine is beyond repair so we're thinking about putting in a zetec s 1.6 engine but im not sure whats involved i.e chang loom etc? the car already had lowered uprated suspension and i will be upgradeing the brakes of course. any help[ would be much appreciated, many thanks
if you put a 1.6 in i think it will all plug up with the standard 1.25 loom but you will need the 1.6 ecu.
would be better if you put the z-s loom in just to be on the safe side
remember to get the chips out of the 1.6 keys so the ecu will let you start the car
1. remove 1.25
2. replace the 1.25 loom with 1.6
3. drop the 1.6 in
4. plug it all in
5. off you go
hope that helps
1. remove 1.25
3. drop the 1.6 in
4. plug it all in
5. off you go
hope that helps
JoeyBoyden
04-01-2024 02:36 PM
track.focus'd
12-08-2015 05:53 PM
