Escort RS1600i This forum is for all things about the Escort RS1600i
Camshaft good??
Old Mar 1, 2018 | 06:25 PM
invade's Avatar
invade
Default Camshaft good??
Hello, what models of camshaft are there for cvh n/a??
Mount a kent cams, but it lasted a short time.
Any ideas??
Old Mar 1, 2018 | 06:38 PM
haz87's Avatar
haz87
Newman solid cam profile. Pain to set up initially but worth it for the longetivity vs others
Old Mar 1, 2018 | 07:39 PM
invade's Avatar
invade
Only kentcams and newmans are manufactured??
Pipercams stopped manufacturing. More??
Now I have a cvh 33 kentcams and solid kent cams followers
Would it be crazy to mix newman cam and kent followers?
Old Mar 2, 2018 | 05:11 AM
haz87's Avatar
haz87
Yes that is not a good idea. The materials will not be matched and so will destroy one another
Old Mar 10, 2018 | 06:48 PM
XR2's Avatar
XR2
Best quality you can buy nowadays for a CVH is a Schrick camshaft. They only sell a 276° one, which is about the same as the car had factory-spec.
Be careful with camshafts that need "cam lobe". This means the companies use stone-age machines for grinding and finishing, so the last finish is done in YOUR engine. Which means you'll have the cam lube and little metal fragments in your engine and this is the last thing you'd like to have. And after all, this kind of "finish" is NEVER as good as when it's done by a proper and modern machine.
turbed dag
14
Jan 22, 2006 01:30 PM
frog
Aug 22, 2004 09:20 PM
aldy
Jul 11, 2004 10:32 AM
mach
Jul 9, 2004 12:51 AM
click
May 19, 2004 04:29 PM
