Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
turn over no fire
Old Jan 3, 2023 | 03:07 PM
Dodgydiver's Avatar
Dodgydiver
Default turn over no fire
so I have purchased a escort xr3i that wont run , apparently it did run 18 months ago. 1993 1.8 silver top xr3i
so new battery and drain all old fuel and replace with fresh fuel
I have fuel at the little valve on the fuel rail ( but dont know if the pressure is right ) fuel pressure gauge kit coming tomorrow
im 99% sure its a fuel issue . occasionally when you start to crank it will fire for a second then nothing
it did have a immobiliser on it but I have fully removed this and re joined the 2 cuts to the loom made
checked the fuel pump and I can hear it running
pulled the plugs and they spark
where do I go next please , any ideas would be great
thanks all
Old Jan 3, 2023 | 03:28 PM
haz87's Avatar
haz87
Is it trying to start at all? If you crank and then pull a plug is it wet?
Assume this was an aftermarket immob? There is a Ford immob fitted as standard too. Red light on the dash should go off with ignition and not flash/go solid when cranking.
Old Jan 3, 2023 | 03:54 PM
Dodgydiver's Avatar
Dodgydiver
The plot thickens. The red light by the clock is constant red all the time once ignition is on.
but. With a squirt of easy start it has fired up. It will run but very very lumpy. It will only rev up a little at a time. The air flow meter makes no difference is connected or not.
there is no chip in the key that I can see.
im more confused than before. There is obviously no diagnostic port on the car
Old Jan 3, 2023 | 06:15 PM
BIG LEE's Avatar
BIG LEE
do you have the red key? or black with red dot if not you may not have chip key so shitty ford alarm will be on..
Old Jan 3, 2023 | 06:16 PM
BIG LEE's Avatar
BIG LEE
it should have obd port in pass side kick well
Old Jan 3, 2023 | 06:19 PM
Dodgydiver's Avatar
Dodgydiver
but I can get it to run tho ?
Old Jan 3, 2023 | 06:20 PM
Dodgydiver's Avatar
Dodgydiver
no main red key or any key with red dot on
Old Jan 3, 2023 | 06:29 PM
BIG LEE's Avatar
BIG LEE
you can get it to run by useing easy start yes this is because ford alarm cuts fuel pump..
Old Jan 3, 2023 | 06:33 PM
Dodgydiver's Avatar
Dodgydiver
The fuel
pump is running. Once it fires on easy start it will run on its own. Just massive hunting and won’t rev up.
Old Jan 3, 2023 | 06:37 PM
Dodgydiver's Avatar
Dodgydiver
so is the shitty alarm only cutting out the fuel pump ? I assumed it did more than that . the pump runs constantly once the ignition is turned on , I would expect it to only run for a few seconds ?
how hard is it to get rid of the alarm thingy , there is a chance that the fuel pump is getting a 12v from somewhere else ?
Old Jan 3, 2023 | 06:42 PM
Dodgydiver's Avatar
Dodgydiver
just been out to double check , there is no transponder ring or any wiring around the ignition barrel
and 100% no chip in the key
is there a chance this was pre pats ?
Old Jan 4, 2023 | 12:16 PM
Dodgydiver's Avatar
Dodgydiver
ok so im 100% sure its not a immobiliser issue ..
ita also not a fuel pressure fault .confirmed its at 3 bar
so how do I check a air flow meter ?
thanks
Old Jan 4, 2023 | 01:28 PM
haz87's Avatar
haz87
Airflow meter won't stop it starting. Zetecs will start and run with it unplugged.
Did you change the fuel filter when you replaced the fuel?
Pulled the injectors and given them a clean? Poor spray pattern could be a cause.
Checked the cam timing (tho I'd expect pops/bangs/or horrible engine noise if it was that out)?
Compression test? Its an unknown engine, could easily be f*cked
Old Jan 4, 2023 | 02:54 PM
Dodgydiver's Avatar
Dodgydiver
Compression was done. All good. Yes new fuel filter.
if I get it started on a whiff of easy start. It will run. But very badly on its own. It will
also re start whilst it’s warm. But once cold then nothing.
Old Jan 4, 2023 | 04:20 PM
Dodgydiver's Avatar
Dodgydiver
ok my clever people ......
so with the ignition on and the pump running at 3 bar , if I put 12v to the injector it gives a beautiful spray of fuel
but cranking there is no fuel . any ideas please
there is deff some thing there as my meter is bouncing up , but dont think there is enough ?
thanks
Old Jan 4, 2023 | 04:35 PM
Dodgydiver's Avatar
Dodgydiver
should I be looking at camshaft or crankshaft position sensors ?
I am deff getting a spark , so that should indicate at least 1 of these is working ?
Old Jan 4, 2023 | 05:03 PM
Dodgydiver's Avatar
Dodgydiver
so I have borrowed a set of noid lights , they deff light up as the engine spins , no way to know if they should be really bright or not but they do light up
yet if I directly add 12v the injector sprays
are they gummed up and the signal is not long enough for them to fire
im so confused here ... im used to cars that have a OBD plug and I can see what's going on
please please please help me before I just start buying more new bits I dont need
Old Jan 4, 2023 | 06:46 PM
BIG LEE's Avatar
BIG LEE
OBD port should be in pass kick well... could be anything tho really
Old Jan 4, 2023 | 07:01 PM
Dodgydiver's Avatar
Dodgydiver
no its pre OBD 1992 . it has that silly 3 pin plug on the inner wing
Old Jan 4, 2023 | 09:48 PM
BIG LEE's Avatar
BIG LEE
ah ryt mk5 xr3i.. could have fuse box issues in that case as there suffer with that aswell..
Old Jan 8, 2023 | 12:03 PM
Dodgydiver's Avatar
Dodgydiver
why cant I upload a small video ?
thanks
File Type: mov
File Type: mov
Old Jan 8, 2023 | 12:04 PM
Dodgydiver's Avatar
Dodgydiver
ahh seems I have done it
YAHOOOOOOOOOO. finally it was. bad ECU giving weak injector signals
Old Jan 8, 2023 | 02:38 PM
cossie2's Avatar
cossie2
Great to hear this..Happy days now
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
X8MRK
Oct 5, 2013 09:02 AM
s12045
Apr 1, 2009 03:00 PM
XRSTI
Ford Mondeo Including ST
Nov 11, 2007 06:50 PM
