Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Rear lights problem. Possible ground issue??
Old Jun 28, 2016 | 06:00 AM
Shaunc's Avatar
Shaunc
Default Rear lights problem. Possible ground issue??
Hi all
Just been checking all my lights to see if any bulbs need changing before MOT on friday and I have a problem with the rear lights and brake lights.
When I press the brake the top bulb in the cluster illuminates, but when I turn the headlights on the top bulb and the bulb second down from the top of the cluster illuminates. Which means when the headlights are on the brake lights dont work!
I've been told this could be a ground issue. If it is a ground issue then where do I look?!
I've uploaded a video to explain it better.
Thanks!
Old Jun 28, 2016 | 06:21 AM
Shaunc's Avatar
Shaunc
https://vimeo.com/172526841
Old Jun 29, 2016 | 01:27 PM
Shaunc's Avatar
Shaunc
Originally Posted by Shaunc
Fixed it.
Turns out it was the earth wire in the boot. It's on the left side next to the convertible roof pump. Needed a good clean
jasoft
May 5, 2016 06:24 PM
sprett86
Apr 30, 2016 02:27 PM
big mikeS
Apr 21, 2016 03:57 PM
Trapper
Apr 13, 2016 10:40 AM
cossie330
Apr 7, 2016 12:06 PM
