Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
mk6 escort control arm bushing
Old Apr 22, 2013 | 04:45 PM
chris104's Avatar
chris104
Default mk6 escort control arm bushing
Hi guys
It seems my lower control arm bushes are shot.
Wil it be a difficult job to replace it,I have a press for the bushes,I'm just concerned about removing the lower control arms
Is there anything I should look out for or know about before I tackle the job
Regards
Old Apr 22, 2013 | 04:52 PM
doga-ot's Avatar
doga-ot
Nope just fiddly getting new ones in I changed my mates few weeks ago in pissing down rain took me 2hrs max. helps with 2 of you!
Old Apr 22, 2013 | 05:15 PM
chris104's Avatar
chris104
Thanks
Old Apr 22, 2013 | 05:19 PM
chris104's Avatar
chris104
One more thing,would worn bushes fuck up the nornal steering carataristics of the car.
Old Apr 22, 2013 | 06:14 PM
doga-ot's Avatar
doga-ot
Yep my mates car only 1 was fucked but its good practice too change both at same time. His car if you accelerated hard front of car actually jumped left and when changing gears same thing happened but to the right and no holding steering wheel or counter steering would stop it, it was lethal on motorways
Old Apr 22, 2013 | 06:17 PM
chris104's Avatar
chris104
My car does the same when changing gears and accelerating
Old Apr 22, 2013 | 06:35 PM
doga-ot's Avatar
doga-ot
Remove front wheels put front of car in the air if you don't have lift, undo the 2 bolts holding each of them to body and the bolt on the ball joint split the ball joint and move hub to one side then they just wiggle out that's the easy bit.
put new one's in use a screw driver to align holes and replace bolts then ball joints and replace wheels lower car job done
Old Apr 22, 2013 | 06:37 PM
doga-ot's Avatar
doga-ot
Also when undoing/doing up the 2 bolts on each wishbone you need to put ring spanner on the nut above.
Old Apr 22, 2013 | 06:44 PM
chris104's Avatar
chris104
Thanks mate for the tips,sound easy enough
Old Apr 26, 2013 | 11:22 AM
chris104's Avatar
chris104
Job done and dusted,what a difference ,car feels planted on the road now
Old Apr 26, 2013 | 11:39 AM
doga-ot's Avatar
doga-ot
good job bud
skypeller
Sep 19, 2015 09:58 PM
FlashRS
Sep 14, 2015 12:36 PM
155lee
Aug 14, 2015 11:21 AM
fatboy billy
Aug 3, 2015 08:34 AM
