Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Escort Van Dials
Old Oct 18, 2012 | 04:27 PM
Dallaway164's Avatar
Dallaway164
Default Escort Van Dials
Hi guys, first post so bare with me i hope ive posted in the right section. ive got a v reg escort van and im looking to fit some dials with a rev counter, would mk6 dials fit and how do i go about wiring up the rev gauge? cheers, tim
Old Oct 20, 2012 | 05:31 PM
////ANTHONY's Avatar
////ANTHONY
hi and welcome to the forum
im no expert but the clock might fit, not sure if the plugs on the back will be the same or not, you would have to find out which wire on the back of the new clocks goes to the rev counter, can do this by following the wire,
you wile have to take a single wire from the ignition coil positive, is your van petrol or diesel?
Old Oct 20, 2012 | 08:08 PM
STeve's Avatar
Super Moderator
the instrument cluster fits no problem, if I remember right a wire needs to be added to the loom that connects to the ecu to get the rev counter working
Old Oct 22, 2012 | 05:07 PM
Dallaway164
thanks for the replys. that sounds good, do you know how i wire it in?
Dallaway164
oh and its 1.8 na diesel
Old Apr 22, 2020 | 02:37 PM
dark_soldier's Avatar
dark_soldier
I know this is an old thread but I thought a reply here might be better than a new thread on essentially the same subject?
My 1.8d van does not have an ECU. It has the later clocks with the digital inset panel. I have purchased diesel digital panel clocks and fitted them, routing the black and white wire from the clocks to the W connector (if memory serves) on the alternator. With the engine started the tacho needle goes to 6k at idle and up (only by 1k as it runs out of dial) when revved. I have bought three sets of clocks now, every seller assured me that they came from a diesel Escort and they all do the same.
Any advice as to how to get this working 'properly' please?
My understanding is that the clocks read pulses generated by the alternator. I tried adding resistors inline with the tacho feed (I had some left over from an aftermarket bike indicator install) but they made no difference. Therefore it must be either modify the alternator (can the pulses be slowed?) or the clocks (can they be 're-calibrated'?)
Old Oct 4, 2020 | 10:51 AM
mk3ste's Avatar
mk3ste
did you get sorted?
Old Oct 4, 2020 | 10:52 AM
mk3ste's Avatar
mk3ste
i want to do the same to my van got no rev counter at the min
Old Oct 4, 2020 | 02:09 PM
dark_soldier
No resolution for me yet - any help appreciated.
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
markk
Sep 9, 2015 08:11 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Bighandsuk
Sep 2, 2015 05:23 PM
