Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
rs2000 4x4 gearbox
Old Sep 7, 2012 | 10:38 AM
brooom...psshh!'s Avatar
brooom...psshh!
Default rs2000 4x4 gearbox
Hi everyone
first of all say sorry if it is not the place to post that and if i should do somthing before posting, is my first time.
i come from spain and i'm posting here because you all know more about ford than anyone else in spain so... i hope you could understand my english.
The question is that i have an RS2000 4x4. i have tested the escort 1.8i 16v 105bhp gearbox and i liked it more than mine. Could i change the gearbox from the 1.8i to the RS2k??
Thanks in advance
Old Sep 7, 2012 | 08:30 PM
STeve's Avatar
Super Moderator
I would say its a bad idea, the best place for specialist rs2k parts and advice is on rs2000-16v.com
Old Sep 7, 2012 | 08:56 PM
20004x4's Avatar
20004x4
the answer would be no unless you were coverting her to 2wd which imo would be a crazy idea, keep it 4x4 mate mine handles lovely round corners
Old Sep 15, 2012 | 11:24 AM
brooom...psshh!
But i shouldn't do it because the torque could break the gearbox or just because it doesn't fit??
Old Sep 15, 2012 | 12:08 PM
Mark_'s Avatar
Mark_
the gear box would be but you wouldn't be able to bolt the transfere box to it,
You would have to convert it to fwd
Old Oct 23, 2012 | 03:25 PM
brooom...psshh!
sorry for the delay and thanks for the reply
I think i will leave it as it is now and i won't have any problem
Old Oct 23, 2012 | 03:43 PM
Mark_'s Avatar
Mark_
They made 4x4's in smaller engines over in europe.
We only had the 2.0 rs2k. They had base model 4x4'x so it may possibly work
I only just found this out myself, Hence the change of mind to my earlier post
Old Oct 23, 2012 | 06:46 PM
Bailes1992's Avatar
Bailes1992
What about the Mondeo 4x4 gearbox?
I would suspect that the ratios would be lower?
Also I always thought that sthe 4x4 gearbox was no different to the FWD models, it just had something that bolted in to the O/S driveshaft 'hole' on the gearbox?
Old Oct 23, 2012 | 06:57 PM
Mark_'s Avatar
Mark_
4x4 gear box's are very different to the fwd version, The casing is different aswell as having a viscous coupling,
The mondeo box is totally different and it favours fwd where are the escort is a 60/40 power split in favour of the rear wheels
Nov 1, 2015 06:53 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
cossie330
Sep 27, 2015 04:13 PM
mpilk
Sep 27, 2015 09:21 AM
