RS 2000 fan belt
Hello all i am new to this site and was wondering if any one could give me some advice. I got a mk6 rs 2000 and having jip trying to change the fan belt i have tried two after market belts and no joy and now got a ford belt and still no joy. Do you have to take a pulley off to get the new one on thanks.
a couple of things to try count the teeth on old one compare it to new one take a look at manual lastly have a look online see if any body else has had same problem good luck with it
There is groves and not teeth thanks thou. I have tried so many times i cant be the only one that has had this problem it would do me in if i had to take the car to a garage for such a simple thing like a fan belt thank again.
Job done i took the power steering pump pulley off put the belt on and then over the pump pulley then with a little pull the pulley went back on thank god for that. For such a simple job what a load of head work but easy that way.
![biere.gif](https://passionford.com/forum/images/smilies/biere.gif)
07-10-2015 12:56 PM
