Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Exhausts???
Old Feb 28, 2004 | 08:02 PM
D7AKE's Avatar
D7AKE
Default Exhausts???
Is there an off the shelf stainless exhaust for the 1600i???
Si
Old Feb 28, 2004 | 08:15 PM
and whilst we are on the subject, will it fit a ghia?
Old Feb 28, 2004 | 09:50 PM
tvr t340r's Avatar
tvr t340r
Default exhaust
yes , theres a few as far as i know, ive got a scorpion stainless on mine that follows the original pattern which goes over the rear arm and is quite quiet, you can have mine if you want one but you need to buy the car, its only £500 needs some welding but is genuinely a good car, see rsowners club for pictures in the 16i section
Bryan Guest
Old Feb 29, 2004 | 12:53 PM
It's Czech Mate's Avatar
It's Czech Mate
Yup, Janspeed now do a full stainless system. Over the the rear arm.
Or I believe Camskills make an exact copy of the original system in stainless too.
Stick to a sensible bore tho! Anything over 2.5-3 inches will be detrimental to performance I'm told.............
Old Feb 29, 2004 | 03:36 PM
Quickie's Avatar
Quickie
yeah you dont want a stoopid drain pipe hanging out the back
Old Feb 29, 2004 | 04:42 PM
anyone know if the 1600i system will go onto a ghia without mods? if not what system will?
Old Feb 29, 2004 | 10:19 PM
Quickie's Avatar
Quickie
yes it will do but not an easy one to get hold of a 3i one would be easier and cheaper
Old Mar 1, 2004 | 07:42 PM
Just the info I needed quickie
Ta m8
Old Mar 3, 2004 | 01:00 PM
i had janspeed system and manifold on my second Rsi ,, stainless on my first one which was much too loud!!! i think Janspeed is the best for these
sound quite Raspy and fairly small size tailpipe,, not too expensive
either,, i would go for that personally KGS did used to have a janspeed by the way
Old Mar 4, 2004 | 10:01 PM
Quickie's Avatar
Quickie
The Janspeed is about £350 for an RSi from Burton
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
