Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Mk6 Rs2k Problems
Old Mar 3, 2008 | 07:13 PM
slimrs2k's Avatar
slimrs2k
Default Mk6 Rs2k Problems
Now then folks
I'm after some advice.
I have a MK6 2wd RS2000 with 76000 mile and FSH.
The gearbox pack up over christmas and me and a mate change the clutch gear box, lambda probes front wheel bearings and wish bones while it was off the road. However since then its had a bit of a miss fire and has been using a fair bit of petrol.
I started it this morning to go to work and the mis fire was more prominant than usuual but disappeared when i got about a 100 yards down the road, i drove it home tonigh no probs, stopped at a red light and it started mis firing, (it sounded like a WRX impreza!!!), i drove it the rest of the way to my garage very gingerly, and popped the bonnet, it seemed like there was water (or petrol) coming from the surface between the exhaust manifold and no. 2 cylinder, and it was sounding rough, then it started chucking lots of white/grey smoke out the exhaust.
Anyone got any ideas?
chris
Old Mar 3, 2008 | 08:24 PM
trev27's Avatar
trev27
Head gasket!!!!!! Maybe!!
Old Mar 3, 2008 | 08:30 PM
slimrs2k's Avatar
slimrs2k
thought so, b##*"Łd!
Old Mar 3, 2008 | 09:00 PM
tonyrally's Avatar
tonyrally
passionford god
Wink
dont jump in at the deep end. are you sure its not driping from sumwere else? also the misfire could be due to wet lead, coilpack, dodgy plugs ect ect u be better of checking out a few things before u pull the head off. also if u have had box off ect check your earths an multi plug conecters are all intact clean an atached thanks tony
Old Mar 3, 2008 | 10:51 PM
kitchy's Avatar
kitchy
RS2000 4x4
the wiring to the coilpacks is notorious for breaking down on RS2000's causing a missfire, hope its not your headgasket mate
Old Mar 4, 2008 | 08:34 AM
slimrs2k's Avatar
slimrs2k
its chucking out whits smoke and the header tank stinks of oil and petrol, and the oil on the filler cap is starting to get that nasty yellowy creamy texture.
Think its the head gasket mate, i put it on ebay as spares or repar this morning,ick its had Ł1500 out of me since christmas.
Old Mar 4, 2008 | 09:41 AM
stuey650's Avatar
stuey650
You sure you put the lambda's back on the same way as they came off?? heard of similar problems in the past after people have replaced these and its cuase they've put them back on the wrong way round. The could explain the overfuelling and the misfires, doesn't explain the header tank/oil filler symptons they do point to h gasket. I'd def be tempted to swap the lambda's round as it only takes 5 mins to see if it makes any difference.
Old Mar 4, 2008 | 12:06 PM
PintoPhil's Avatar
PintoPhil
Listing number??
Old Mar 4, 2008 | 02:54 PM
slimrs2k's Avatar
slimrs2k
listing number mate
Old Mar 4, 2008 | 07:33 PM
DAVE 29's Avatar
DAVE 29
my rs is for sale mateif ur looking for another and limited addition as well its on ebaymate
Old Mar 5, 2008 | 08:19 AM
slimrs2k's Avatar
slimrs2k
I,ve got a S2 RST in the garage that i have been restoring so i'm running round in that at the moment, cheers though mate
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
