Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
RS2000 Group A engine' s specifications
Old Nov 23, 2006 | 05:51 PM
MK5RS2000's Avatar
MK5RS2000
Default RS2000 Group A engine' s specifications
I cherch specifications of Group A engine.
I have the book "Motorsport Formula 2, Group A Rally Preparation Manual", but i Dont say engine' s modifications.
Old Nov 23, 2006 | 06:20 PM
rs_daz's Avatar
rs_daz
This is the spec for the rs2000 MAXI.The spec of the engine is not known much tho I cant find much about it the Maxi engine spec ,it was all done by mountune tho and main info i found was modified crankshaft, con-rods, pistons, flywheel, inlet, sump, valvegear, ancilliary drives, electronics, maps and headwork..
Activity: (1998-1998)
BHP@ RPM 282/8500
Torque (Nm)@ RPM 255/6500
Length Width Height 4140.1830.1378
Wheelbase 0
Weight (Kg/BPM Ratio) 960 (0)
Transmission FWD
Engine Type
Engine Position
Engine Capacity 4
Engine Bore Front Transverse
Engine Stroke 1998
Engine Compression 86
Engine Valves 86
Engine Cams 12.0:1
Engine Carburation 4
Engine Electronics 2 OHC
Suspension Injection
Body Doors 2475
Body Type 3.4
Body Composition 3
Body Panels Hatchback
Brakes Steel
Fuel Tank 0
Wheels 0
Old Nov 23, 2006 | 07:32 PM
MK5RS2000's Avatar
MK5RS2000
OK, thank you
Do you know if is it a EEC IV or an other "computer"?
Old Nov 24, 2006 | 05:53 PM
rs_daz's Avatar
rs_daz
Think it was some different management used...
Old Nov 24, 2006 | 06:52 PM
MK5RS2000's Avatar
MK5RS2000
Its a maxi, the same engine management in the white RS2000 "fast ford" May 2005. She' s very very nice.
In the Group A manual, it' s not a kit car, 4 trottle body, but there is 1 trottle body, but i don' t say more.
Old Dec 16, 2006 | 12:22 AM
Paul_RS's Avatar
Paul_RS
Originally Posted by MK5RS2000
OK, thank you
They used Pectal management
Old Dec 17, 2006 | 12:10 PM
MK5RS2000's Avatar
MK5RS2000
OK thank you.
SmudgerByName
52
Jul 28, 2016 06:14 PM
3drRich
Sep 13, 2015 07:32 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Old ford
Jul 31, 2015 06:50 AM
