bodymen question, 2k paint
Old Feb 27, 2012 | 07:17 PM
kieran_macca's Avatar
kieran_macca
Default bodymen question, 2k paint
Any bodymen on here that can answer this, spraying the sierra and I want the finish to be second to none, its primed and all panels perfect, now usually when I'm prepping for paint I will sand to p500 and grey scratchpad, then paint, the finish is good but I was wondering if I was to sand further than that, e.g. Wet 800 grit etc, will the finish appear any better? And how far can I go with wet sanding (1500, 2000, etc) until the paint doesn't have much to grip to.
I may also add the paint will be pure white, mipa 2k so it should be good covering.
Any info is greatly appreciated.
Also I guess while I'm at it what's the best grit for flatting and polishing after paint, so I can leave a good show car finish and shine, thanks
Old Feb 27, 2012 | 07:48 PM
neil andeRSon's Avatar
neil andeRSon
we just use 500 before applying 2-3 coats of 2pack paint. and for polishing up i use 1500 wet. try getting some of 3m's new fast cut. iirc the buffer we have at work is set to 1500-2000 rpm.. i can double check that tomorrow tho..
http://www.ebay.co.uk/itm/3M-Perfect...item1e66e71709
Old Feb 27, 2012 | 08:11 PM
dingla rs's Avatar
dingla rs
2k soild white 400 discs will be fine ,its a good gun and set up that will get ur finish ,after paint i use 2000wet an dry an some 3m fast cut polish
Old Feb 27, 2012 | 08:19 PM
neil andeRSon
What gun an set up do you use mate? I'm on a devilbis gti with a 1.3 tip an a 110 cap. I was using a 1.4 tip but recently changed.
Old Feb 27, 2012 | 08:32 PM
dingla rs's Avatar
dingla rs
i have a gti 1.3 110 for solids and clear 115 for basecoats but just orderd a new iwata as i fancy a change had the gti 13 years
Old Feb 27, 2012 | 09:12 PM
neil andeRSon
i'm on the same set up for basecoats as my laquer/solid gun. does the 115 make much odd's? let me know how you get on with the new gun..
Old Feb 28, 2012 | 01:23 AM
kieran_macca
thanks, thats what i would have used, just keen to know what others use and if it improves finish, i didnt use any discs after primer, i used a block and p320 sheets followed by 500 sheets to be sure to have it as flat and smooth as possible
it will be a satajet 3000rp gun used for this respray, quality gun!
thanks again for the help/reassurance
Old Feb 28, 2012 | 06:36 PM
dingla rs's Avatar
dingla rs
yer although its a 105 aircap my mistake lol ,its great i find the fan patten is bigger never use out else for basecoats
Old Feb 28, 2012 | 06:40 PM
botters's Avatar
botters
competant bodger
that 3m fast cut is the dogs bollocks! buffing takes no time at all
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
rsguy
44
Sep 29, 2015 03:29 PM
