Cleaning Aluminum
Old Nov 17, 2011 | 01:50 PM
JayCC's Avatar
JayCC
Default Cleaning Aluminum
Hi, got a Bailey header tank, and in my infinite wisdom, I didn't screw it on tight enough! So now it is marked.
I've tried Silvo and a few microfiber cloth's. But it's taking FOREVER!! Do I just have to piss into the wind until it finally rubs enough away?
Anyone got a tried and tested way that'll reduce my stress level? It's pissed me right off.
Thanks in advance, Jamie.
Old Nov 17, 2011 | 03:26 PM
jimhc's Avatar
jimhc
big jc
Try autosol thats what i use
Old Nov 17, 2011 | 04:00 PM
JamesH's Avatar
JamesH
Meguiars all metal polish - the best I've used by far!
Old Nov 17, 2011 | 04:54 PM
JayCC's Avatar
JayCC
Cheers, will have to go get some!
I've got a fair bit of it off, it's just left a stain.
Old Nov 18, 2011 | 06:23 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you could use fine wet and dry sand paper, 1000grit f it's really bad then autosol over that for hours.
personally just persevere with autosol or meguires.
Old Nov 18, 2011 | 07:14 AM
puma38's Avatar
puma38
Autosol, i used to use it on my yamaha pw50 when i was 4, still use it now nothing out there is better.
Old Nov 18, 2011 | 07:19 AM
JonnyBravo's Avatar
JonnyBravo
I used stuff called peek, brilliant stuff but haven't used anything else so couldnt common on the others
Old Nov 18, 2011 | 07:22 AM
Isaac.Hunt's Avatar
Isaac.Hunt
If it's a persistent stain or a scratch, then I'd go with fine wet and dry using WD40 or a thin machine oil as a lubricant. The Aluminium will be left dull afterward but can easily be buffed back to a shine with any decent metal polish.
chowfornow
14
Jan 5, 2019 09:01 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
hopper350
Sep 4, 2015 12:53 AM
