snow foam????
Old Mar 8, 2011 | 03:43 PM
mintseries1's Avatar
mintseries1
Default snow foam????
hi all,
heard a few people talk about this now, is it what its cracked up to be??? is it worth it?? and what is the best product to buy???
i fancy trying it, but if its a waste of me monies then ill give it a miss.
cheers andy
Old Mar 8, 2011 | 03:51 PM
lead_foot's Avatar
lead_foot
is awesome
Meg's hyper wash works well.
Sorry, you need a lance aswell.
Old Mar 8, 2011 | 04:07 PM
mintseries1
it that a " snow foam" ????
im not taking the the piss lol i just dont know!
Old Mar 8, 2011 | 04:17 PM
RichieST's Avatar
RichieST
I use snow foam and it is alright, but definately not worth the money, by the time you've shelled out for a gun etc. I only keep using the kit because I've got it!
Old Mar 8, 2011 | 04:18 PM
Mike C's Avatar
Mike C
The Special One
It doesn't say the words "Snow Foam" anywhere on the container, but I will second that it is the best product on the market to use as a Snow Foam. Polished Bliss also agree with this.
What you need is a decent pressure washer, a quality foam lance (£44.95 from cleanyourcar.co.uk) and some Hyper Wash, then you're ready to roll.
Old Mar 8, 2011 | 04:20 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I'm actually starting to learn a bit about all this detailing malarky now, and the sceince of it is quite interesting although I still dont really enjoy doing it much so leave it to the mrs instead, she's weird enough to actually enjoy it
There was a couple of threads on this the other day
Lance thread:
https://passionford.com/forum/concou...oam-lance.html
snow foam thread:
https://passionford.com/forum/genera...snow-foam.html
older snow foam thread:
It works really well, stays on for ages and gives the detergent time to break the dirt down, and if you wish to agitate it manually as well with a microfibre mitt or whatever its really easy to do so (best to only do that after its had one rince at least in case of particles you might scratch the paint with).
You need the lance AND the product, you cant just use the product on its own.
Old Mar 8, 2011 | 04:33 PM
mintseries1
bloody hell that was over 7 months ago!!
the reason i ask is we just got a new karcher and it came with a lance i thought was for snow foam! now seeing the one talked about above the one ive got seems crap, lol
so should i perchase i lance like the above and what product should i use for best results.
cheers andy
Old Mar 8, 2011 | 04:41 PM
Chip's Avatar
Chip
Yes you need a lance, and something like megs hyper wash as mentioned above.
Old Mar 8, 2011 | 04:53 PM
mintseries1
wicked cheers for the comments just read up on them threads.
cheers andy
Old Mar 9, 2011 | 02:22 PM
Mike C's Avatar
Mike C
The Special One
This is a specialist lance that you won't get with any pressure washer, it needs to be bought from a specialist.
Well worth it though.
Old Mar 13, 2011 | 12:56 AM
Blunt.RS's Avatar
Blunt.RS
I personnally only use it for quick ness and it does a great job
I wouldn't use it on my toys though
As I find it leaves the paint abit greasy unless I got the mixture wrong
But great stuff
Old Mar 13, 2011 | 09:29 AM
baba's Avatar
baba
If youve a strong enough washer the foam really does a good job much better when its heated water also.
And ive tried several foams and megs hyper wash is all i buy now.Remember it dilutes sumit like 400-1 so a greasy finish is probably due to being to strong.
Work out what your washer and gun flows to empty the bottle and add product accordingly.
Old Mar 13, 2011 | 10:44 AM
Retro Al's Avatar
Retro Al
RWD IS KING
But great stuff
Thats because its supposed to be a pre wash procedure just for releasing as much dirt from the car before you use a proper shampoo, and dont forget snow foam is TFR derived and you can get ones that are quite strong like tfrs
Old Mar 13, 2011 | 03:09 PM
Blunt.RS's Avatar
Blunt.RS
I shall have to expermint cheers
Ah not really a good idea then to use on its own then
Old Mar 13, 2011 | 05:16 PM
baba's Avatar
baba
No you dont use it on its on the idea is to use it to remove the intergrated dirt before you hand wash it.
I usually give car a rinse then foam her up leave for 5 mins or dependant on weather as temp diffrence in air makes a diffrence to product,wash product off.Then re-foam and after 5 mins wash using the tbm.
Old Mar 13, 2011 | 08:15 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Its a good quicky on its own, if your cars well protected and just a little dirty then its fine, if its really dirty i would always wash afterwards with the typical 2 bucket.
Just got the lance from cleanyourcar.co.uk and a new pressure washer, going to try the megs stuff out this week
Old Mar 16, 2011 | 04:14 PM
st170dan's Avatar
st170dan
i use snow foam and i definately think its worth it. the point of is to loosen and/or remove as much of the grit as possible before you wash with a mitt (not a sponge!!) so that you are dragging less grit across the paint and inflicting less damage to it. if you care about your paint then regardless of the cost it is worth it. as mentioned you need a proper lance, not the one supplied with the PW. they can be bought at a number of detailing shops. you'll also need the correct fitment for your lance ie a karcher fitment. you can use hyperwash or buy a dedictaed snow foam. remember to dilute it with water in the lance - it foams just as well and you get better value from your foam. hth.
Old Mar 17, 2011 | 04:13 PM
david 100's Avatar
david 100
I was given a container of snow foam but i have a pressuer washer but no lance so i just tried a little foam in one of those pump up sprayer things and i never realy got much foam but it got off the dirt so i could wash it with a mit without scratching the paint, i know a lance would be better but i am happy with the pump up method
Old Mar 17, 2011 | 06:17 PM
st170dan's Avatar
st170dan
with snow foam the lance creates a thick foam that hangs on the car, loosening the dirt. without a lance the foam is thinner, doesnt hang as long as isnt as effective.
Old Mar 17, 2011 | 06:40 PM
Blunt.RS's Avatar
Blunt.RS
I used this method for a while which i thought was good results
but youll be amazed what a difference the proper lance makes deffo worth the money
Old Mar 28, 2011 | 09:38 AM
st170dan's Avatar
st170dan
snowfoamed my housemates car this weekend so i did a quick pic to show you. didnt do a before as i had the idea too late, but during:
and after
as you can see the car is already pretty clean meaning that the 2 bucket wash we did next was alot safer. and the importance of 2 bucket wash:
looked pretty clean but clearly wasnt!
Old Apr 22, 2011 | 10:13 PM
david 100's Avatar
david 100
Got the proper lance now and its great, got the wife good and proper, coverd her in foam, had to make sure it was all right before trying it on the cossie
Johnny Knoxville
Sep 30, 2015 07:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
