best machine technique for newbies.
Old Aug 26, 2010 | 11:06 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default best machine technique for newbies.
Now ive been shown the basics of using a rotary polisher and had a go on my car to do some minor correction.
But wanting to do it properly I'm worried its easy to do a lot of damage with a rotary eg burn through etc.
Ive heard DA polishers are much "safer" but i presume with safety comes a trade off with a DA's ability to remove paint defects???
can you still achieve removal of most swirls and still work down deeper paint defects like on a rotary??
and is the technique any different??
So what is the best compromise for the DIY/amateur looking to keep his own paintwork in good nick??
Old Aug 26, 2010 | 11:21 PM
Psycho Warren
Carbon Crazy
can a mod move this to the right room please! done a spaz and posted it in wrong place!
Old Aug 26, 2010 | 11:23 PM
Frenchy0204's Avatar
Frenchy0204
Get to tha choppa!
Not entirely true in most circumstances. DA's are indeed safer, but providing you have the correct polishes for the paint finish, you can acheive the same amount of correction as a Rotary, it will just take longer due to the DA being a gentler machine.
As said above, you can but it will take longer. Bare in mind that even Rotarys can occasionally not manage to remove deeper marks. A lot of the times, this means the car will require wet-sanding in that area, which is a completely different ball game.
Not really. Technique is pretty much the same, working the Polish in at Varying pressures and speeds.
Everything comes with experience. There is no compromise. Providing you have taken every pre-caution beforehand, you should do fine. The most important thing before polishing is prepping the car, so things like Paint Readings, Clay-Barring and Taping Up all need to be done. If that has all been done and you are happy with the Results, then take a deep breath and have a shot. If your really worried about ruining your paint though, then maybe look into practicing on some body panels from a scrap yard, or a old car with tired paint if you have one.
P.S, I would strongly suggest grabbing a cuppa and having a read of this Warren. It will really help you learn.
http://www.detailingworld.co.uk/foru...ad.php?t=63859
Good luck! Be sure to sign upto Detailing World and show pictures of your Car in the showroom when it is done.
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
