Brake Discs
Old Oct 11, 2007 | 11:54 AM
cos im worth it's Avatar
cos im worth it
On here to much!!
Default Brake Discs
Hi guys, thought you guys would be the ones to ask, whats the best thing to clean up a set of rear discs that have been standing a bit and have gone slightly rusty on the vented edges and the centres where it bolts on, also they are drilled and groved and look a bit rusty in the wholes and groves, was thinking about skipping the edges and centres over with some 180 discs and painting them up, is it worth cleaning out the groves and drilled wholes and painting them too or would it just be waisting my time once they were fitted and used, any sudgestions welcome, Cheers Mark
Old Oct 11, 2007 | 11:57 AM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
I would take the disks off, clean them up with a wire brush tool in your drill, paint them with some VHT or similar all over, put them back on the car with an old set of pads and take it easy braking untill the surface of the disk has cleared the paint...then swap the pads back to a good set and hey ho you have a painted disk all over excet the braking surface.
Dan
Old Oct 11, 2007 | 12:00 PM
cos im worth it
On here to much!!
I like it mate, discs are off anyway and old pads still in.
Old Oct 11, 2007 | 06:36 PM
SillyFezzaMk1
Rubber Rhino Crew
Yeah I've done this a few times now, as I always change disks and pads together I always have an old set of pads handy for such job
Dan
Old Oct 11, 2007 | 06:44 PM
redrsmk5's Avatar
redrsmk5
Default Re: Brake Discs
OMG mark you bufty Even i dont clean brake discs
Old Oct 11, 2007 | 10:18 PM
cos im worth it
On here to much!!
Might have known you'd be hanging around in here Bufty Boy! ha ha. i'm going to have to do something drastic so i can contend with the underside painted crew! SillyFezzaMk1 cheers for that mate sounds like a plan, by the way am liking the MK1 mate
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
