cpu temp
Old Nov 8, 2005 | 10:24 PM
Chris Honeywell's Avatar
Chris Honeywell
Default cpu temp
What sort of temp range should they be running?? normally
Cause i bought a mag today saw how i could check the temp at start up and after 2 hours of being on it was running at 83c
Took the comp apart and found the heatsink completly filled up with dust
I have now cleaned it up
Old Nov 8, 2005 | 11:05 PM
MikeyXR2i's Avatar
MikeyXR2i
Mines running at 40.c, which is well good. 83 is way to high, whas it running at now u cleaned it up?
Old Nov 9, 2005 | 12:17 AM
Dan B's Avatar
Dan B
CPU: 32 degrees (AMD Athlon XP2600+)
Motherboard: 15 degrees
What CPU is it? If that's not an AMD, I'm surprised it didn't pop at a temperature that high!
Old Nov 9, 2005 | 06:33 AM
Chris Honeywell
m8 the cpu is a P4 2.8ghz...
Old Nov 9, 2005 | 06:34 AM
Chris Honeywell
Old Nov 9, 2005 | 08:07 AM
DanRSturbo's Avatar
DanRSturbo
My AMD Xp3200 usually runs around the 42 degrees mark, doesn't really change much under load and with the system on 24 / 7
You're very lucky that didn't go pop. Tony Turbo's P4 chip went pop a while back as a result of heatsink / fan failure. Burnt a hole through the chip
Old Nov 11, 2005 | 02:00 PM
adamS2RST's Avatar
adamS2RST
I just checked my temps in the bios:
CPU Temp: 43 Degrees C / 109 F
System Temp 28 Degrees C / 82 F
That about right ? Seem's to not budge more than that under load
Old Nov 11, 2005 | 02:40 PM
DanRSturbo's Avatar
DanRSturbo
That's fine then m8
Old Nov 11, 2005 | 03:55 PM
Dan B's Avatar
Dan B
Mine sits nicely at:
Idle:
CPU: 32 Degrees C
Mobo: 18 Degrees C
Load:
CPU: 38 Degrees C
Mobo: 22 Degrees C
Bit of a weird cooling method, at the moment, though, until I get the new case......case-side removed, 12" deskfan directed inside the case, and regular clean-outs with a "dust-buster" compressed-air canister!
Old Nov 11, 2005 | 05:01 PM
xpackcapri's Avatar
xpackcapri
Old Nov 11, 2005 | 05:12 PM
DanRSturbo's Avatar
DanRSturbo
I thought that too m8, until Tony's did
Old Nov 11, 2005 | 08:43 PM
ZSDavey's Avatar
ZSDavey
CPU 33c under load
System 22c Constant
HDD 30c Constant
P4 3.0ghz, Maximum recommended Temp is 65c i do believe, anything more than that and it starts to throttle down like xpackcapri said!
David
Old Nov 11, 2005 | 09:06 PM
adamS2RST's Avatar
adamS2RST
Originally Posted by ZSDavey
CPU 33c under load
System 22c Constant
HDD 30c Constant
David
MY AMD chip is set to do that at 65
Old Nov 11, 2005 | 09:08 PM
Chris Honeywell
well shes fine now
running at 42c
Old Nov 11, 2005 | 10:19 PM
Dan B's Avatar
Dan B
Keep an eye on your heatsink from now on!
Old Nov 14, 2005 | 11:12 PM
Chipperx2's Avatar
Chipperx2
How do you check?
Old Nov 14, 2005 | 11:15 PM
xpackcapri's Avatar
xpackcapri
Old Nov 14, 2005 | 11:30 PM
Dan B's Avatar
Dan B
Mine's with a program that came with my motherboard, called Asus Probe......it monitors quite a few things, like CPU temperature, motherboard ambient temperature, fan speeds, voltage-stability, memory usage, hard-drive usage, and so on.
Old Nov 15, 2005 | 09:28 AM
adamS2RST's Avatar
adamS2RST
Also from the bios
Old Nov 15, 2005 | 10:57 AM
xpackcapri's Avatar
xpackcapri
Old Nov 15, 2005 | 11:17 AM
adamS2RST's Avatar
adamS2RST
Originally Posted by xpackcapri
bios will give a higher reading than when in operating system as the cpu will run at load whereas in the os it will be idle.
I though't that was the case Which in turn means my system should be cooler than I first thought
Old Dec 12, 2005 | 12:04 AM
Thrush's Avatar
Thrush
Irritating c........
I have a Dell Optiplex GX270 P4 2.8 - how do I check CPU temp?
Old Dec 12, 2005 | 12:16 AM
xpackcapri's Avatar
xpackcapri
Old Dec 12, 2005 | 01:27 AM
Zetec Andy's Avatar
Zetec Andy
Download everest, tells you everything you want to know about your PC!
http://www.pcadvisor.co.uk/downloads...6&itemID=23043
Mine was reading 55C under load and idles at around 43C
Old Dec 12, 2005 | 10:38 PM
Thrush's Avatar
Thrush
I used that link Andy, go to download, sends me to a different page, click accept on the liscence thingy then all I get is ERROR 404 FORBIDDEN page come up
Mark RS
Oct 12, 2015 06:01 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
Ben26
Sep 3, 2015 07:55 PM
