Connected to BE..
Old Oct 20, 2005 | 08:19 PM
DaveH's Avatar
DaveH
Default Connected to BE..
... and to start off with..I was syncing at 8mb down..1mb up...but my SNR was at 5.5/6... and I dropped a few times...
I had a brain wave... a while ago..a mate ran an extension up to my loft from the master socket... I removed the faceplate..and plugged it direct in to the socket behind the face plate... my stats are a little better now
Bandwidth (Up/Down) [kbps/kbps]: 1.249 / 18.000
Data Transferred (Sent/Received) [KB/KB]: 92,00 / 427,00
Output Power (Up/Down) [dBm]: 12,0 / 18,0
Line Attenuation (Up/Down) [dB]: 10,0 / 20,5
SN Margin (Up/Down) [dB]: 8,0 / 6,5
I know my SNR is low..but it's improved .5 and my download has increased by 10mb..and it's alot more stable now...
Only problem..I had to escalate a call to the London engineers as the Speedtouch 716 they provide is shit...and I can't set my firewall up on the DMZ..so all my servers are out of action at the mo
Gonna kick butt tomorrow and get it resolved asap...
But still..i'm happy with my line stats now
Just got to fit the filtered faceplate (when it arrives)
I'm off to download the entire internet now.
Old Oct 20, 2005 | 09:38 PM
Dan B's Avatar
Dan B
18Mbps downstream, nice!
Very similar line-attenuation to my line (21dB down, 7.5dB up, with 31dB up/down SNR on a 2Mbps circuit), so I'd probably end up with very similar connection-speeds through BE as you have.
And yes, they purposefully run the SNR pretty low, so as to get decent speeds (pretty sure they've released a new profile for people having problems, which uses 10dB as the SNR lower-limit, to give a more stable line at a possibly slightly lower speed).
Old Oct 20, 2005 | 09:50 PM
DaveH's Avatar
DaveH
Yup, they have got a 10db profile as well... or for people who have got Netgear GT routers...there is a patch to manually specify your own target SNR... so you can play about and find the optimum settings for your line...
I know I'll probably be moaning in a couple of days about my net being down... but it's a pilot... i'm expecting it...and since sorting out my faceplate...I really can't fault the service...
If they can't sort out my issue with the speedtouch being able to set up a DMZ..I'll just go out and get the Belkin ADSL2+ router..as that has some favourable reviews on early ADSL2+ tests...
Old Oct 20, 2005 | 11:45 PM
Dan B's Avatar
Dan B
I've got a NetGear DG834G v2 (the ADSL2+ compliant version) wouldn't mind trying it out on a 24Mbps-enabled line, to be honest, just to see how it copes...
Old Oct 20, 2005 | 11:54 PM
DaveH's Avatar
DaveH
What version firmware are you running ? I can't remember if it was the G or the GT version..but I think they said the G version works better with 2.10.10 firmware (or later)
Old Oct 21, 2005 | 09:05 AM
Dan B's Avatar
Dan B
G, v2.10.22
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Flatlinedan
Sep 18, 2015 12:41 PM
