PSU Problem
Old Oct 19, 2005 | 05:31 PM
adamS2RST's Avatar
adamS2RST
Default PSU Problem
OK, I work in I.T so know enough But when it comes to your own pc maybe it's just me, but you fix pc's all day long and when your's develops a problem you just ignore it!
Basically from startup it seems my power supply unit is making a nasty noise (sounds like the fan) but it is deffo still turning, anyway by the time the o/s loads it stops (and yes the fan is still spinning ) I have cleaned out the PC, and can't see any problems, I guess it's new PSU time?...my next question is....where do you all buy your parts from? I am planning on building another PC and want to get hold of some cheap good spec bits
Old Oct 19, 2005 | 06:26 PM
CosRush's Avatar
CosRush
I'd recommend the following:
Overclockers.co.uk (my favourite)
Watfordelectronics.co.uk
Aria.co.uk
RLsupplies.co.uk
Hope this helps..........
Old Oct 19, 2005 | 08:16 PM
DaveH's Avatar
DaveH
ebuyer.com
scan.com
komplett.co.uk
cclonline.com
Old Oct 19, 2005 | 10:36 PM
xpackcapri's Avatar
xpackcapri
Old Oct 19, 2005 | 10:41 PM
Dan B's Avatar
Dan B
http://www.scan.co.uk because it's just up the road from me...
And I only ever buy Enermax power-supplies......current one is a 600W "NoiseTaker".
Old Oct 19, 2005 | 10:51 PM
xpackcapri's Avatar
xpackcapri
Old Oct 20, 2005 | 06:40 AM
adamS2RST's Avatar
adamS2RST
the psu maybe undegoing too much stress when the system is booting as obviously everything is running at full speed. does it do it when you run stressful programs?
this next bit is potentially dangerous so i take no responsibility for any injuries you could get from doing this.
switch the psu off at the back and disconnect from the wall.
unplug the psu from the motherboard (i would unplug from other devices too but you can leave fans in)
test the psu by bridging pins 13 (black wire) and 14 (green wire) on the psu's motherboard connector. switch on at the wall and then the back of the psu. the psu will switch on.
obviously if it makes no noise, you know its stress on the psu causing it to do it. if it still makes a noise then chances are its knackered. you could test all your voltage rails while youre doing this as well.
Yea, i'll have to have a play about mate, it only does it on boot and at no other time, although there is a slight constant "whirring" which Ican only assume is that fan, i'll have a good look tonight
Old Oct 20, 2005 | 05:33 PM
monkey24's Avatar
monkey24
try your local computer fair and only buy from stall holders that are fairly close to you incase anything fails and needs taking back....i got a new m/board pentium 4 3ghz processor 512 ddr heatsink and fan etc....basically everything i needed for under Ł300
Old Oct 21, 2005 | 07:53 AM
DanRSturbo's Avatar
DanRSturbo
It's a fan failure, simply just get a new psu
Old Oct 21, 2005 | 10:00 AM
adamS2RST's Avatar
adamS2RST
Yes Dan, that'd be the best solution, any recommendation on a psu? I could just replace with the same model I guess from my local pc place, what advantage is there having a higher powered one?
Old Oct 21, 2005 | 10:50 AM
Dan B's Avatar
Dan B
If you upgrade any parts in the machine (graphics card, mainly, but extra hard-drives can also play a part), then a lower-powered PSU could have a chance to brown-out (ie. temporarily not supply enough power to all devices). Mine did this, until I noticed I had my graphics card and two hard drives running on a single molex-rail from the PSU......random reboots galore, especially when gaming.
Old Oct 21, 2005 | 12:40 PM
adamS2RST's Avatar
adamS2RST
Hmmm, that'll likely be the reason then, added an extra drive a couple months back - Best get it sorted asap, a machine's psu @ work went bang today in a big way!
Old Oct 21, 2005 | 05:34 PM
Dan B's Avatar
Dan B
Worst I've had was an old hard-drive go pop (well, one of the chips on the drive's board, anyway). The chip (which was about the size of a thumb-nail) exploded with enough force to put a small dent in the computer-case!
Old Oct 22, 2005 | 09:22 AM
DanRSturbo's Avatar
DanRSturbo
So, your pc spat a pc chip through the block
Old Oct 23, 2005 | 07:39 PM
MikeyXR2i's Avatar
MikeyXR2i
I got a Colours IC PSU 550 Watt, excellent bit of kit.
The fan lights up all different colours. Not that makes much of a difference lol.
Old Oct 27, 2005 | 03:43 PM
tonyk's Avatar
tonyk
A proper 600w psu will cost at least Ł50, you see psu claiming to be 600w for Ł12, these are not 600w and when put under test did not run near that amount of power.
For the average pc a psu running a real 350w is enough. If you run a lot of hard drives, fans, optical drives and a beefy cpu and graphic card then you will need more. Custom PC magazine done a proper load test on psu last month and it showed some surprises to say the least.
hi-spec system http://www.scan.co.uk/Products/Produ...oductID=179312
lo-spec system http://www.scan.co.uk/Products/Produ...oductID=138556
This is and the like are a waste of money http://www.ebuyer.com/customer/produ...duct_uid=61300
Old Oct 27, 2005 | 06:32 PM
DanRSturbo's Avatar
DanRSturbo
Agreed tony, this is more suitable
http://www.ebuyer.com/customer/produ...duct_uid=90611
Old Oct 27, 2005 | 06:48 PM
adamS2RST's Avatar
adamS2RST
Cheers folks for the info.
The blasted thing has been fine for the last few days, but will pickup a new psu at the weekend anyway I think!
Old Oct 27, 2005 | 07:07 PM
DanRSturbo's Avatar
DanRSturbo
Better to be safe then sorry m8
Old Oct 27, 2005 | 07:30 PM
adamS2RST's Avatar
adamS2RST
Yes mate
Old Oct 29, 2005 | 06:57 PM
adamS2RST's Avatar
adamS2RST
Cheers for all your advice lads. Now sorted
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
