Web design gurus?? Help needed???
Old Mar 2, 2005 | 11:28 AM
MadMac's Avatar
MadMac
Default Web design gurus?? Help needed???
I'm using Dreamweaver to make a website.
Basicly at the header of each page is a picture of a car. I have been trying to work out how to make it randomly choose a different picture from a libary I have of them on line. So hopefully everytime the page is refreshed, it randomly picks out a new picture to put at the top of the page. But I'm not having much luck as I am shite at Java script.
Anyone know how to do it?
If ya can help that would be soooper
Old Mar 3, 2005 | 12:10 PM
boon's Avatar
boon
Hi
I've never used dreamweaver, but this should do what you're after.
There are 3 constants you'll need to setup - i've put a "TODO" comment so you can easily see them.
The code assumes all your pics will be the same type (eg .JPG). Simply name them all sequentially starting at 1, e.g. carpic1.jpg, carpic2.jpg etc and away you go.
Good luck,
Boon
Code:
<html>
<head>
</head>
<body>
<script type="text/javascript">
var prefix = "\\img\\car\\carpic";			// TODO set the path to your set of pictures
var suffix = ".jpg";						// TODO set the type of image (assumes they're all the same type)
var num_pics = 10;							// TODO set your max pic number (first assumed to be 1)
// Pick a random number between 1 and num_pics...
var r = Math.random();
var pic = Math.round(r*(num_pics-1))+1;
// debugging only, remove when you're happy :)
document.write("When the page loads, it will show the following image : ")
var name = prefix + pic + suffix;
document.write( name+"
// Output the HTML to display your picture...
document.write("<IMG SRC=\"");
document.write( name );
document.write("\" alt=\"");
document.write("\">");
</script>
</body>
</html>
Old Mar 3, 2005 | 12:16 PM
MadMac's Avatar
MadMac
Thank you thank you!!! Just what I was after
And soo much simpler than the others I have seen
Old Mar 3, 2005 | 12:22 PM
boon's Avatar
boon
No problem. I'm a simple person, so everything I do is simple...
Old Mar 3, 2005 | 12:24 PM
MadMac's Avatar
MadMac
best way to do it when it comes to programming
Been so long thou I can't remember how to do it
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
jc1989rs
Aug 15, 2015 04:58 PM
col93saphcos
Aug 7, 2015 03:21 PM
