Pc help, what's died?
Old Aug 10, 2011 | 04:46 PM
Fil's Avatar
Fil
ELASTIC BAND
Default Pc help, what's died?
Built a new pc friday, been fine.
Left it on, came b back from the shops 30 mins later, and now all I've got is a black screen with a flashing cursor in the top left hand corner of the screen an inch down.
Power off / on , it starts up, bios etc, then when you get to the bit where windows should start to load, you get the black screen and cursor?
Stuck to using my phone now, so not great for googling help!
Old Aug 10, 2011 | 04:48 PM
D16PJM's Avatar
D16PJM
sounds like the operating system to me, will it not load in safe mode.
Old Aug 10, 2011 | 04:57 PM
Fil's Avatar
Fil
ELASTIC BAND
Nope, no safe mode
Tried booting from the cd drive first, with a windows disk in, but still the same.
Pulled each stick of ram, still the same
Pulled out agfx card and used onboard..........still the same?
Old Aug 10, 2011 | 05:20 PM
Eagle's Avatar
Eagle
Super Moderator
hard drive died ?
should go through the boot process, then if you press the del key it should go into bios.. then see if it sees a hard drive ...
might be a dodgy sata connection on the hdd or board but if you left it on and working sounds like something died and it rebooted....
Old Aug 10, 2011 | 05:27 PM
Fil's Avatar
Fil
ELASTIC BAND
Just fired up the hard drive on another board, all seems well. Now formatting and going to out it back into my main new build
Old Aug 10, 2011 | 05:29 PM
Fil's Avatar
Fil
ELASTIC BAND
And bugger, a mods here, looks like a been right sectioned, where no one looks compared to general dis
Old Aug 11, 2011 | 08:14 AM
Eagle's Avatar
Eagle
Super Moderator
and lol .....
Old Aug 11, 2011 | 09:37 AM
cozmeister's Avatar
cozmeister
More boost Igor!
If the only thing on the screen is the flashing cursor, disconnect EVERYTHING except the monitor - USB devices (inc keyboard and mouse), drives (hdd and cd). Then try powering it up again. It's not unknown for machines to refuse to pass the POST if a USB device won't respond to a reset command, usually USB hubs are the most common for that.
If the machine actually does a POST, IDs drives and memory etc, then there should be nothing to stop it booting. Failing that, aim for the CMOS reset jumper/button (again with no devices connected, then try booting it.
Old Aug 11, 2011 | 02:14 PM
Fil's Avatar
Fil
ELASTIC BAND
Originally Posted by Eagle
and lol .....
I knew i done wrong, just hoped i'd get away with it a bit long in GD
sorry
Sorted, tho, completely formatted the HDD last night before work, and just completed the reinstall, all running for now.............
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
