Any cisco experts on here?
Old Mar 15, 2011 | 02:38 PM
timb551's Avatar
timb551
Default Any cisco experts on here?
I need some help setting up a 3750 switch.
Can anyone help?
thanks
Old Mar 15, 2011 | 03:18 PM
carcollector's Avatar
carcollector
oooo....ios......what u wanna know ?
Old Mar 15, 2011 | 03:22 PM
timb551's Avatar
timb551
Hi
I basically have a fibre feed coming into my building, which i goes to a fibre termination unit.
i then have a cat5 feed coming from that into the cisco switch.
I have a main external ip address which i have been told i need to set on the port on the switch which goes to the fibre termination unit.
I then have various external ip addresses which i want to set to partiular ports on the switch.
Does that make sense?
Old Mar 15, 2011 | 03:30 PM
carcollector
Originally Posted by timb551
Hi
sounds like a VLAN setup or did i understand this the wrong way ?
Old Mar 15, 2011 | 03:39 PM
carcollector
read it again and it doesnt make any sense....why would you want to set external adresses to certain ports ? if you need to talk to the switch from the WAN then 1 is enough and i cant even see a reason for that.
put it in a visio diagram if u want and i look @ it.
Old Mar 15, 2011 | 03:41 PM
carcollector
PM'd u back m8
DavidK
Sep 27, 2015 02:55 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Mark Mawson
Aug 31, 2015 07:09 PM
Jim Galbally
27
Mar 17, 2005 11:24 AM
21
Sep 4, 2004 09:27 PM
