no sound on tv for xbox 360!
Red 90 Spec s2 RS Turbo
can anyway help me gettting sound to work please?! worked fine on old tv and now on new tv got a picture but no sound,
Cables all connected to correct colours on back of tv, i.e blue,red,green connections with colour bands, and white and red sound in-put and out-put in right place, but no sound with picture! if i change channel i do get sound but no pic! just a blue screen,
Its on a HD tv and little switch on cable on HD so am lost of what to do next!!!!!
if you get sound and video, but on different channels, then your xbox is working fine, but you've either cabled up the TV wrong or the setup on the TV needs changing
PUG 306 GTI-6
Irritating c........
By the sound of it you've connected the component (red, blue, green) cables for video, and analogue stereo RCA (red and white) for audio, and the fact you are getting video but no sound, then on a different "channel" you get sound but no picture means you HAVE connected the audio to the wrong input.
if you can tell me the make model of your TV I can probably find a manual online and show you which inputs you need to use. Either that or sometimes, on some TV's, audio inputs can be assigned to different video inputs.
Post the make and model and we'll get to the bottom of it......
Model 42PF7621D/10 AND product number QG-1A0627 017179
Hope this enough info
This is from the Phillips website (I can't access the PDF manual I found cos of shitty works computer)
- Connect the X-box 360 with the X-box- HD component cable to EXT 3 of the TV Red Green and Blue cinch connections (the yellow cinch connector is not connected).
- Connect the audio separately, with the red and white cinch connectors for audio on the HD cable to the analogue audio input which is a mini-jack connection for EXT3 of the TV or the optical out from the Xbox (via a converter) to the digital coaxial input of the TV.
- You may need to re-assign the audio on the TV to the correct connection :
Select TV MENU and press cursor right. The TV menu appears on screen.
Select INSTALLATION and press cursor right. The installation menu is moved to the left.
Select CONNECTIONS and press cursor right. The connections menu is moved to the left.
Select L/R and press cursor right. Select NONE
Select DIGITAL AUDIO IN and press cursor right. Select EXT 3.
Press MENU/BROWSER to exit the menu.
Think we on right track but still having trouble getting sound with pic, tried all possible sound options but still only sound with blue screen, cheers for the info mate, any chance of some more lol
07-10-2015 12:56 PM
