disaster!!!! (hdd access help)
Old Sep 9, 2008 | 06:53 PM
Stephen_B's Avatar
Stephen_B
I actually Bum This Place
Default disaster!!!! (hdd access help)
right formatted my pc onto a separate partition last night (still have existing one). I want to access my files on existing partition and when i try and get into the my documents folder it says access denied. Any way I can get this back again as I have everything on there.
Any help would be appreciated
Old Sep 9, 2008 | 07:13 PM
Stephen_B's Avatar
Stephen_B
right managed to fix it but now if i double click it trys to search and the only way to view folders is to explore. I know its probably a simple box tick but not sure how to do it
would be greatful for some hellp thankyou
Old Sep 12, 2008 | 11:09 AM
DanRSturbo's Avatar
DanRSturbo
Christ knows what you have done here Are you saying that you split your current hard drive partition into 2, leaving one operating system on it, and installed a second operating on the new partition, and now your trying to access the original partition with all documents on it ?
If so what operating systems are you using ?
Old Sep 12, 2008 | 11:26 AM
Nash_mr2's Avatar
Nash_mr2
did you format using the same file system NTFS or FAT etc - sounds like it could be a permissions issue
need more details
Old Sep 14, 2008 | 06:49 AM
Stephen_B's Avatar
Stephen_B
need more details
sorted the permissions issue out but everytime i double click folders now in anything other than :C drive it opens a search window instead. You can right click then 'open' but this starts to get annoying after a while. Any way round that?
Also now i have internet problems. It did it before formatting, so although I wanted to format anyway it was an excuse to do it sooner. I thought I'd buggered some obscure setting up, and when I formatted the internet connection is fine. But as of just the problems come back again. I've not fiddled any settings, but the internet logo in the corner says no connection (but aol logo says there is - so theres internet) but the connection only lasts for a few minutes sometimes and takes a very longtime to recconect again. And then once connected (knowing with the aol logo saying connection) the windows says theres nothing.
The annoying thing is this usb dongle (a 3com one) was used in my dad's pc for over 2 years with no problems, and then I pinched it cos it was better than a dodgey wireless card I bought. So its worked fine ford ages and now its as if there are compatibility problems
Can anyone help?
Old Sep 14, 2008 | 02:23 PM
DanRSturbo's Avatar
DanRSturbo
Yeah, i'd learn from this mistake and format the entire drive and start again
To fix Ao hell you'll probably need to uninstall it and reinstall it, then reconfigure the wireless settings.
You've provided no explanation as to what you was trying to do, nor what operating system so all I can concur from what you have done is you had C: and thought "i know, i'll split that and have some room" rather then buy a 2nd hard drive and install it.
Old Sep 14, 2008 | 04:51 PM
Stephen_B's Avatar
Stephen_B
the connection problem is windows/dongle not aol. The routers ok too as I'm posting off the other PC. And yeah, your right, I wacked a partition on the end cos Im too tight to buy a harddrive
Old Sep 14, 2008 | 06:13 PM
Stephen_B's Avatar
Stephen_B
its fixed - for now touch wood
Guess how I did it....
I unplugged the dongle and plugged it in again
Old Sep 15, 2008 | 08:34 AM
DanRSturbo's Avatar
DanRSturbo
And that fixed everything ?
Old Sep 15, 2008 | 07:09 PM
Stephen_B's Avatar
Stephen_B
well the internet side of things. Im guessing that disk think where it tryes to search everything is some simple setting somewhere as it happens when I put my memory card into the computer aswell as data CD's. Its just finding it...
gingeRS
17
Oct 2, 2015 09:42 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Si B
Sep 12, 2015 06:49 AM
