Windows Validation problem.
Old May 22, 2008 | 11:10 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Default Windows Validation problem.
On my brothers PC, I installed a genuine version of windows XP Home about a month ago.
Yesterday he booted it up, logged in as normal and the screen said he needed to validate his copy of windows. So "OK" was clicked, and it said that windows was already validated, and then returned him to the log-on screen.
The computer is now in a circle of doing this and cannot be accessed at all except in safe mode.
Anyone any idea how to sort this out without reinstalling, his constant moaning and nagging is beginning to piss me off
Old May 22, 2008 | 11:48 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
try the windows validation diagnostic site
http://www.microsoft.com/genuine/diag/
Here's common issues and how to resolve them
There are two possible solutions here. One is caused by a permissions problem in the registry. To fix this issue, follow the steps below:
1. Click Start, and then click Run
2. In the Open box, type regedit, and then click OK
3. Expand HKEY_CLASSES_ROOT
4. Locate the subkey HKEY_CLASSES_ROOT\LegitCheckControl.LegitCheck
5. Right-click the subkey and select Permissions….
6. Ensure that Administrators allowed Full Control permission
7. Repeat steps 3-6 for the subkey
HKEY_CLASSES_ROOT\LegitCheckControl.LegitCheck.1
If this does not fix the issue with KB905474 update not installing, download the update to your desktop and manually install it.
1. Click on the link below to download the KB905474 update manually
http://www.download.windowsupdate.com/msdownload/update/v3-19990518/cabpool/windowsxp
-kb905474-enu-x86_4bafa8793e8cdcaf4ba4ffc494df32d496154544.exe
2. On the File Download Window, click Save and choose to save the file to your desktop.
3. After the file downloads, go to your Windows desktop and double-click on the file named
windowsxp-kb905474-enu-x86_4bafa8793e8cdcaf4ba4ffc494df32d496154544.exe
4. Follow the instructions on the screen to install it
5. Reboot your computer and go to Windows Update to check if the update as installed successfully.
Another reason why the validation may fail occurs when the ActiveX control for the Windows Genuine Advantage Validation Tool has been disabled. Follow the steps below to make sure the ActiveX is enabled.
1. Open Internet Explorer
2. Click on Tools, Internet Options
3. Click on the Programs tab
4. Click on the Manage Add-ons button
5. Find the Windows Genuine Advantage Validation Tool and click on it
6. Verify the Add-on is enabled, if it is not. Click Enable and Ok twice to exit back to Internet Explorer.
7. Close Internet Explorer and reopen it. Now try to validate Windows again.
A third error deals with Cryptographic Errors. If you are receiving the following information when running the WGA diagnostic tool, the problem is generally with corruption in the digital signatures of some files and they will have to be reregistered.
Diagnostic Report (1.5.0545.0):
WGA Data-->
Validation Status: Cryptographic Errors Detected
Follow the steps below to resolve these cryptographic errors.
1) Click on Start, click on Run
2) In the Open box, type CMD and then click OK.
3) At the command prompt type the following command and Press Enter
regsvr32 softpub.dll
4) You should receive a message that DllRegisterServer in Softpub.dll succeeded, click OK
5) Repeat Steps 3 and 4 to re-register the following files
  • wintrust.dll
  • initpki.dll
  • dssenh.dll
  • rsaenh.dll
  • gpkcsp.dll
  • sccbase.dll
  • slbcsp.dll
  • mssip32.dll
  • cryptdlg.dll
6) After all the above files have been re-registered, type Exit at the command prompt to close it and return to Windows.
7) Restart Windows and try to authenticate Windows again.
A fourth error message you may receive when trying to validate Windows XP is
This error message occurs when you do not have appropriate permissions for the DATA folder for Windows Genuine Advantage. Follow the steps below to fix this issue or click on the link above for the Microsoft article concerning this problem.
Windows XP Professional or Windows XP Home
1. Click Start, click Run, type the following in the Run dialog box, and then click OK:
%systemdrive%\Documents and Settings\All Users\Application Data\Windows Genuine Advantage.
2. Right-click the Data folder, and then click Properties.
3. On the Security tab, click Users (username\Users) in the Group or user names section. If the Security tab is absent, you'll need to follow these steps as well.
  • Open My Computer
  • Click on Tools
  • Click on Folder Options
  • Click on the View tab
  • Uncheck the option for "Use Simple File Sharing"
  • Click Ok and go back to Step 2 above and try again.
4. In the Permissions for Users section, make sure that each check box in the Allow column is selected for the following permissions:
• Read & Execute
• List Folder Contents
• Read
5. Click OK, and then restart the validation check process.
If the previous steps fail, start the computer in Safe Mode and try the procedure again.
HTH... all else fails : install Linux
Old May 22, 2008 | 12:41 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Originally Posted by Turbocabbie
HTH... all else fails : install a copy that doesnt need to be activated
I agree mate!!!
Old Jun 13, 2008 | 08:24 PM
DanRSturbo's Avatar
DanRSturbo
Gracey,
When the machine is first powered on tap the F8 key until you get the startup menu, once done try last known good configuration, or safe mode and try turbocabbies suggestion, if of course it let's you into windows, failing that try the step by step guide on repairing XP.
Old Jun 14, 2008 | 09:18 AM
Rodge.'s Avatar
Rodge.
Originally Posted by Lee_R21Turbo
I agree mate!!!
I agree too! *cough* XP corp SP3 slipstreamed! *cough*
chowfornow
14
Jan 5, 2019 09:01 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
