Routa help!
Old Apr 22, 2008 | 01:03 PM
jamesm cossie's Avatar
jamesm cossie
Default Routa help!
Hello guys
My office has a 3COM Super Stack II routa with 7 computers plugged into it via a workgroup setup. All computers work no problem and see each other no problem.
When I plug our new BT Business Hub broad band into the routa all 7 computer can then work on the internet but cant see each other.
The BT Business Hub has 3 ports in the back and if I plug three of the computers into they all see each other and work on the internet no problem, obviously I need to plug all 7 computers in though so what is my best bet?
Kind regards
James
Old Apr 22, 2008 | 09:09 PM
Adrian's Avatar
Adrian
Try plugging the "ROUTER" into port 8 or 16 on the 3COM Super Stack and give it a go.
There may also be a little push button switch on the 3COM unit you may have to fiddle with also.
Old Apr 23, 2008 | 03:54 PM
BigMouthBillyBass's Avatar
BigMouthBillyBass
As above, probably something to do with uplinking, press the switch and see what happens
