Why can't I delete certain files?
Old Oct 11, 2007 | 05:29 PM
Thrush's Avatar
Thrush
Irritating c........
Default Why can't I delete certain files?
I have a couple files/folders on my PC that I "procured" from the internet ( ) which I don't want.... Trouble is the PC won't let me delete them!
I click to highlight, then hit DEL and it thinks for a few seconds, then tells me it can't delete cos the file is being used by another programme But it fucking ain't
Sometimes I have just rebooted and then deleted and it's been fine, but these two (one avi file and one folder containing a different avi file) won't delete!
Why not?
Old Oct 11, 2007 | 05:57 PM
Drewman's Avatar
Drewman
Cos i'ts being used It's not being uploaded on a p2p program at all is it ?
Old Oct 11, 2007 | 06:43 PM
Thrush's Avatar
Thrush
No it's not being used at all.... I know that, as the only two programmes that used each file were 1) uTorrent (to download it) and VLC Media Player (to play it) Both aren't using it, and it has been "deleted" from uTorrents list so I can remove the file from my PC.....
Which is why I can't understand what's stopping me delete the files
How do I find out if any other programme etc is using the file and stopping me delete them?
Old Oct 11, 2007 | 07:35 PM
Alex_86's Avatar
Alex_86
start the comp in safe mode
then delete them
the reason is that if your files it started in winamp, media player, deamon, ect they usually are in the playlist ect
therefore win tell you that its in use
Old Oct 11, 2007 | 08:20 PM
Thrush's Avatar
Thrush
Alex - they aren't in use. They aren't in any WMP or VLC playlists, other files have been played with these programmes since then and they have deleted fine - just these two won't.
I just tried booting into safe mode and deleting - get the same message
Running out of idea's here as I was hoping safe mode would do it and it didn't
Old Oct 11, 2007 | 09:05 PM
Thrush's Avatar
Thrush
Getting on my fucking tits now
Googled and found info stating it's an XP bug that mostly relates to AVI's.... One fix is to cut and paste it to the desktop, then delete. Did that and it worked on one file, but the other isn't working. Then tried three recommended "kill" programmes (Dr Delete, Sure Delete and MoveOnBoot - all of which schedule the file for deletion when windows boots, to avoid Windows trying to "catalogue" the avi) - none worked
FUCKS SAKE
Old Oct 12, 2007 | 03:05 AM
SS1's Avatar
SS1
try treesize..i had a few corrupt files in my torrent folder azures..
every time i tried to open the folder.my net browser would shut down.still dont know why pc seemed virus free..
anyways with treesize i could open program files and delete the nasty ones trial and error just backtracked via download dates and it worked
worth a try http://www.snapfiles.com/get/treesize.html
Old Oct 12, 2007 | 09:39 AM
Thrush's Avatar
Thrush
Tried it, still won't delete it
Old Oct 12, 2007 | 12:08 PM
Alex_86's Avatar
Alex_86
hehe, thats why you should stop with all that porn
try to rename it then delete it
Old Oct 12, 2007 | 12:31 PM
Thrush's Avatar
Thrush
It's not porn
Can't rename
Can't delete
Can't move
Can't edit
Can't open with any programme
Can't do fuck all
Old Oct 12, 2007 | 01:53 PM
Alex_86's Avatar
Alex_86
Originally Posted by Thrush
It's not porn
its animal porn
sorry mate
but recheck all the progs you have used it in. that it aint in the playlist
you could also try to run regedit and search for the file there and delete what ever that comes up
Old Oct 12, 2007 | 02:52 PM
Thrush's Avatar
Thrush
I only tried it with two prog's - WMP and VLC and niehter have it listed so it's not being used....
I don't like doing regedit as it's too easy to fuck it up.....
DOS command DEL doesn't work either
Old Oct 12, 2007 | 09:29 PM
djmillsy's Avatar
djmillsy
Fife Radge
have you tried a system restore to before they arrived?
Old Oct 12, 2007 | 10:09 PM
Thrush's Avatar
Thrush
Millsy - thats the ONE thing I haven't done
Usually it doesn't delete files tho, it just restores settings and moves files, it doesn't delete ones that have arrived after the date you restore to..... Hence why I haven't tried that.....
Old Oct 13, 2007 | 12:31 PM
Drewman's Avatar
Drewman
Right Click > Check "Hidden" > Apply > OK
File gone! to the untrained eye
Old Oct 13, 2007 | 12:46 PM
Thrush's Avatar
Thrush
Thats not getting rid of it tho is it
Old Oct 13, 2007 | 05:23 PM
Drewman's Avatar
Drewman
Goto "Run" type "msconfig" and try and find the offending file under the "startup" tab to see if it's running when Windows boots.
Or have you tried task manager [Ctrl + Alt + Del] to try and see if its running there under "Applications" so you can end process?
Old Oct 14, 2007 | 07:25 AM
Thrush's Avatar
Thrush
I doubt it will be under the start up tab - it's a video file, not a programme....
Like with with Task Manager - it's not in there as it's a video file thats not in use, even tho Windows is convinced it is
Old Oct 14, 2007 | 11:18 AM
Drewman's Avatar
Drewman
Re-install Windows
Old Oct 14, 2007 | 11:54 AM
Thrush's Avatar
Thrush
Fuck right off
Tho I am beginning to think that might be the only option left
But I ain't reinstalling just to get rid of a 700mb file, it's not like I am short on space - but it's pissing me off as I don't want it, don't need it, but mostly cos Windows is winning and I don't want it too I tell the PC what it can and can't do - not the other way around!
Old Oct 14, 2007 | 01:18 PM
djmillsy's Avatar
djmillsy
Fife Radge
have you found the pre fetch file and deleted it then tried to delete it
Old Oct 14, 2007 | 02:16 PM
Alex_86's Avatar
Alex_86
regedit mate, search for the file.. delete the key that comes up with the file name.. then delete the file
Old Oct 14, 2007 | 02:31 PM
Thrush's Avatar
Thrush
Nope cos I have no idea what a pre fetch file is
Old Oct 14, 2007 | 04:41 PM
Hockney's Avatar
Hockney
http://ccollomb.free.fr/unlocker/ will delete files that are a fucker to remove
Old Oct 14, 2007 | 05:02 PM
Thrush's Avatar
Thrush
YOU ARE A FUCKING GOD!!!!!!
Went first time, no fucking around - right click, "Unlocker", ticked "delete" from the drop menu and BAM - file deleted in about 1.5seconds
Hock, you really are the fucking MAN!
THANK YOU!
Old Oct 14, 2007 | 07:36 PM
DanRSturbo's Avatar
DanRSturbo
The other option would of been to move it to either one of your other hard drives, or one of your other pc's you have lying around and then delete it.
Old Oct 15, 2007 | 08:55 AM
Thrush's Avatar
Thrush
Dan;
Can't rename
Can't delete
Can't move
Can't edit
Can't do fuck all
Nov 1, 2015 06:53 PM
