wireless hardware switch
Old Jan 25, 2007 | 06:55 PM
glancy2081's Avatar
glancy2081
Default wireless hardware switch
hi tried to use laptop wireless and when went to install it asks me to turn on hardware switch how do u do this
Old Jan 26, 2007 | 01:27 AM
DanRSturbo's Avatar
DanRSturbo
What router or access point are you using ?
Old Jan 26, 2007 | 12:20 PM
glancy2081's Avatar
glancy2081
bt home hub router
Old Jan 26, 2007 | 01:31 PM
DanRSturbo's Avatar
DanRSturbo
Oooh, i was talking about this in the pub the other day. If you want to open certain ports on it, you will need to ring BT to do it.
But, AFAIk connecting it wirelessly should be the same as with any other router, open http://192.168.1.1 or http://192.168.0.1 or whichever the manual tell's you to open, then setup the wireless network, and it should be as simple as that really
Old Jan 26, 2007 | 10:03 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
it could be asking for you to enable the wifi hardware switch on the laptop as some can be switched on and off... what laptop is it
Old Jan 26, 2007 | 10:08 PM
Turbocabbie
Top Cab !!
You do not need to call BT to open ports as these are within your control on the router.
When configuring the router it should be done hard wired via the Ethernet connections... routers which allow remote or wireless access configuration have security issues which need to be taken into consideration
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
xrmalin
Sep 13, 2015 06:52 PM
