windows xp home sp2
Old Dec 30, 2006 | 04:31 PM
cozzy's Avatar
cozzy
Default windows xp home sp2
just installed sp2 on my pc everthing installed but when it rebooted it stop on the windows xp home part and thats it nothing will work
Old Dec 30, 2006 | 05:06 PM
djmillsy's Avatar
djmillsy
Fife Radge
i had the3 same prob is your copy of xp a real one the only way i could do it was to load it up on safe mode and reinstall the first edition i personally dont like sp2
Old Dec 30, 2006 | 05:13 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
are you getting any error messages ?
if not i bet your installing from a DVD drive is that a good guess ?
Old Dec 30, 2006 | 05:37 PM
djmillsy's Avatar
djmillsy
Fife Radge
yeah if your are installing from A dvd drive you can run the software from that drive you just need to set you boot drive
Old Dec 30, 2006 | 05:43 PM
cozzy's Avatar
cozzy
getting no errors and am runnig it from dvd drive how do i set boot drive
cheers
Old Dec 30, 2006 | 07:13 PM
djmillsy's Avatar
djmillsy
Fife Radge
i cant quite remember you press f2 or f12 which ever one for your set up when the computer swithces on then you go to boot up opions and slect run from the drive and that should hopefully be you
Old Dec 30, 2006 | 07:25 PM
cozzy's Avatar
cozzy
cheers will give it a go
Old Dec 30, 2006 | 07:44 PM
djmillsy's Avatar
djmillsy
Fife Radge
Old Dec 30, 2006 | 09:27 PM
Turbocabbie
Top Cab !!
the BIOS in some systems look for a optical CD drive and do not boot correctly a DVD drive, these systems usually have a boot menu which you access by pressing F11 or similar (its a F Key or Function Key) and select the DVD as the first boot.
If you have installed SP2 on a Windows Installation that was allready installed and running prior to SP2 you should be able to access Windows in safe mode by pressing F8 as it is booting and selecting Safe Mode from the option menu...Once you have entered Windows try closing it don and booting it normally, if this does not work you may be able to remove SP2 in safe mode
Old Dec 30, 2006 | 09:46 PM
djmillsy's Avatar
djmillsy
Fife Radge
what he said if you cant get on then hit safe mode and get rid of it as i say i dont think its that good anyway
Old Jan 1, 2007 | 06:41 PM
cozzy's Avatar
cozzy
think its sorted just installed it and it rebooted without any cheers
Old Jan 1, 2007 | 09:22 PM
djmillsy's Avatar
djmillsy
Fife Radge
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
cossie330
Sep 27, 2015 04:13 PM
