PC Guru's How can i make my PC faster?
#41
what about vista? ive got a dell laptop i put loads of pics on there from time to time and the computer runs really slow at times even if with no pics on there cant follow the guidlines but to no sucess ive used cc for a while but even that doesnt make it run that much quicker / any ideas??
Microsoft do not use it internally in many departments.
Dell do not use it internally
and now the largest CPU manufacturer is not upgrading to it
http://www.reghardware.co.uk/2008/06...s_no_to_vista/
#42
10 Simple Ways To Speed Up Windows XP
1. Disable Indexing Services
Indexing Services is a small little program that uses large amounts of RAM and can often make a computer endlessly loud and noisy. This system process indexes and updates lists of all the files that are on your computer. It does this so that when you do a search for something on your computer, it will search faster by scanning the index lists. If you don’t search your computer often, or even if you do search often, this system service is completely unnecessary. To disable do the following:
* Go to Start
* Click Settings
* Click Control Panel
* Double-click Add/Remove Programs
* Click the Add/Remove Window Components
* Uncheck the Indexing services
* Click Next
2. Optimise Display Settings
Windows XP can look sexy but displaying all the visual items can waste system resources. To optimise:
* Go to Start
* Click Settings
* Click System
* Click Advanced tab
* In the Performance tab click Settings
* Leave only the following ticked:
* Show shadows under menus
* Show shadows under mouse pointer
* Show translucent selection rectangle
* Use drop shadows for icons labels on the desktop
* Use visual styles on windows and buttons
3. Speedup Folder Browsing
You may have noticed that everytime you open my computer to browse folders that there is a slight delay. This is because Windows XP automatically searches for network files and printers everytime you open Windows Explorer. To fix this and to increase browsing significantly:
* Open My Computer
* Click on Tools menu
* Click on Folder Options
* Click on the View tab.
* Uncheck the Automatically search for network folders and printers check box
* Click Apply
* Click Ok
* Reboot your computer
4. Disable Performance Counters
Windows XP has a performance monitor utility which monitors several areas of your PC’s performance. These utilities take up system resources so disabling is a good idea.
To disable:
* download and install the Extensible Performance Counter List
* Then select each counter in turn in the ‘Extensible performance counters’ window and clear the ‘performance counters enabled’ checkbox at the bottom.button below
5. Improve Memory Usage
Cacheman Improves the performance of your computer by optimizing the disk cache, memory and a number of other settings.
Once Installed:
* Go to Show Wizard and select All
* Run all the wizards by selecting Next or Finished until you are back to the main menu. Use the defaults unless you know exactly what you are doing
* Exit and Save Cacheman
* Restart Windows
6. Optimise your internet connection
There are lots of ways to do this but by far the easiest is to run TCP/IP Optimizer.
* Download and install
* Click the General Settings tab and select your Connection Speed (Kbps)
* Click Network Adapter and choose the interface you use to connect to the Internet
* Check Optimal Settings then Apply
* Reboot
7. Optimise Your Pagefile
If you give your pagefile a fixed size it saves the operating system from needing to resize the page file.
* Right click on My Computer and select Properties
* Select the Advanced tab
* Under Performance choose the Settings button
* Select the Advanced tab again and under Virtual Memory select Change
* Highlight the drive containing your page file and make the initial Size of the file the same as the Maximum Size of the file.
Windows XP sizes the page file to about 1.5X the amount of actual physical memory by default. While this is good for systems with smaller amounts of memory (under 512MB) it is unlikely that a typical XP desktop system will ever need 1.5 X 512MB or more of virtual memory. If you have less than 512MB of memory, leave the page file at its default size. If you have 512MB or more, change the ratio to 1:1 page file size to physical memory size.
8. Run BootVis - Improve Boot Times
BootVis will significantly improve boot times
* Download and Run
* Select Trace
* Select Next Boot and Driver Trace
* A Trace Repetitions screen will appear, select Ok and Reboot
* Upon reboot, BootVis will automatically start, analyze and log your system’s boot process. When it’s done, in the menu go to Trace and select Optimize System
* Reboot.
* When your machine has rebooted wait until you see the Optimizing System box appear. Be patient and wait for the process to complete
9. Remove the Desktop Picture
Your desktop background consumes a fair amount of memory and can slow the loading time of your system. Removing it will improve performance.
* Right click on Desktop and select Properties
* Select the Desktop tab
* In the Background window select None
* Click Ok
10. Remove Fonts for Speed
Fonts, especially TrueType fonts, use quite a bit of system resources. For optimal performance, trim your fonts down
to just those that you need to use on a daily basis and fonts that applications may require.
* Open Control Panel
* Open Fonts folder
* Move fonts you don’t need to a temporary directory (e.g. C:\FONTBKUP?) just in case you need or want to bring a few
of them back. The more fonts you uninstall, the more system resources you will gain.
if you find these tips usefull I will post some advanced tweaks for the more adventurous of you
* Go to Start
* Click Settings
* Click Next
* Go to Start
* Click Settings
* Click System
* Open My Computer
* Click Apply
* Click Ok
To disable:
Once Installed:
* Restart Windows
* Reboot
* Download and Run
* Select Trace
* Reboot.
* Click Ok
* Open Fonts folder
#44
Great tips @ Turbocabbie
I only use some softwares like Advance Cleaner (?), spybot and AVG to clean my PC but the suggestions you gave are really awesome. I've actually forwarded your post to a friend and we will perform your suggestions soon.
__________________
The first step in the acquisition of wisdom is silence, the second listening, the third memory, the fourth practice, the fifth teaching others.
atlanta concrete driveway|conversion optimization
__________________
#45
PM for PCS
Go into yout task manager (contrl , alt , delete, ) and make sure you are running so many prgrams thats using up your free memory, alot of time the programs running will bog down your system due to the fact you have to much, if so go into processes and look and see what programs are using a large amount of your memory, make sure to do your PM , like defragin your hard, running anti-virus/spy ware, another thing that can bog down your pc is how much data you have stored in your hard drive, for the fuller your hard drive is the slower response time you;re gonna get.if these things do not restore the speed of your pc, then you may need to look into your hardware, for memory goes bad, along with g cards, if everythign checks out you may jsut have to due a factory restore, and start new, but make sure to back up any files you are wishing to keep
#46
Search for the 'System 32' folder and delete it, this will improve your computers speed dramatically.
I am kidding DONT do this
You can try doing the standard Disk Cleanup and Defrag, clear out your recycling bin, go through the programme list (accessed via control panel) and uninstall programs you dont use. Do you get any clunking noises coming from the unit when its starting up or loading stuff?
#47
This needs updating now the tech is stable: buy an SSD.
My pc boots in 12 seconds, I never get any lag any more and I never need to defrag.
I run a Samsung 840 PRO and it is awesome. Probably the best component in the PC!
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
TPM961
15-01-2018 10:50 AM
