Connect3d ATI Radeon 9550 AGP 256MB
Ok so I have the above graphics card....
bought from : Here
and the reviews say people can run Doom 3 Halflife 2 BF 2 on high settings without any problems, but I can't even run Gta:san andreas with it. it freezes after a while then the PC restarts....i mean wtf?!
I have an AMD Athlon 3000+ and 1GB of RAM and I do not see why I am having troubles...
any suggestions?!!
bought from : Here
any suggestions?!!
Which drivers have you installed for it? A review here (see 2nd comment) seems to suggest it's not fully compatible with the latest drivers......could be causing the issue.
Do you get any error messages, or does the PC literally lock up then restart?
Also, have a look in the event-viewer, which should give you some clues as to what's happening. This should be within the Administrative Tools section of the Control Panel (but is "hidden" by default - for 2000: right-click on taskbar, Properties, Advanced tab, find the tickbox that says "Display Administrative Tools", put the tick in it, then OK; for XP, from memory, it's right-click on task-bar, Properties, 2nd tab (I believe called Start Menu), click on the Customize button that's highlighted, THEN Advanced tab in the new window, then similarly-named radio-button in the options).
Once you've opened the Event Viewer, right-click on any "incident" and select Properties, then see what the text says - paste it in here, if you're unsure what it means...
everytime i post a problem i seem to solve it myself lol
i read in the reviews that his kept crashing so put it down to x4 and it stopped.
i've just done this and played gta for a good 20mins flawlessley, so this seems to of solved it.
any more problems i'll be back!!
cheers dan
but i don't have enough knowledge to be able to know what's causing it to crash.
i just read someone had the same problem, put it down to x4 and it solved it
so i did that lol
Paul J
Computers, Consoles and I.T.
06-01-2006 06:00 PM
Joris_FRST
25-04-2005 10:34 AM
Jim Galbally
40
26-02-2005 12:05 PM
