help with wireless
Old Aug 12, 2006 | 02:35 PM
swerv's Avatar
swerv
Default help with wireless
right when i set my parents computer up for wireless i put an encryption on it, when i connect now it says its a unsecured network?
how do i re-enter a key?
also how do i see who is connected to the network?
Old Aug 12, 2006 | 05:05 PM
L33 BYT's Avatar
L33 BYT
If your using a router/modem you can usually see who has obtained a DHCP address.
Will be labelled like "DHCP Lease table or similar"
If your window is showing unsecured network then WEP has been turned off. Most access points/wireless routers have a web based console. Think you need to check your setup.
Old Aug 19, 2006 | 09:24 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
You have to enter the wireless router or access point.
This is usually done through a web browser (the default web address can usually be found on the bottom of the device) and will be something like http://192.168.0.1 at that point you will be prompted for a username and password
Enter this and you should be also to see the settings for the device including the encryption protocol used.. if your devices supports it use WPA-PSK or WPA, WEP should only be used as a last resort because its secure as a paperbag.
NOTE :- you are better off doing this hard wired to the device with a ethernet cable because as soon as you encrypt the device your wireless access may drop until you set the computers connection up using the encryption codes.
Thrush
Computers, Consoles and I.T.
Oct 19, 2005 03:24 PM
Snowy_Astra
Sep 29, 2005 04:03 PM
Gra
11
Aug 13, 2005 01:45 PM
BigNige
Nov 20, 2004 12:02 AM
Turbo lag
Sep 6, 2004 06:57 PM
