removing something from my registry
Old Jul 26, 2006 | 03:49 PM
dreamin's Avatar
dreamin
Default removing something from my registry
as above having a few probs with photoshop and been told in a brief convo that after uninstall i need to do the above anyone help please???
Old Jul 26, 2006 | 05:17 PM
L33 BYT's Avatar
L33 BYT
This is not meant offensivly. BUT its the control point of your entire PC. One wrong change and it could be game over.
However I will make a suggestion. Do a google for registry cleaners. That should remove all the toot from the Install.
Always make a backup though. Go to start>>Run>>Type Regedit and export the file.
Old Jul 26, 2006 | 05:22 PM
dreamin's Avatar
dreamin
cheers lee so exporting it wont remove it ?
Old Jul 26, 2006 | 05:52 PM
BM08's Avatar
BM08
here you go, download, install and run
http://www.download.com/TweakNow-Reg...-10262639.html
Old Jul 26, 2006 | 05:53 PM
dreamin's Avatar
dreamin
will do gti itg thanx
Old Jul 26, 2006 | 05:58 PM
L33 BYT's Avatar
L33 BYT
Exporting wont remove. Simply create a backup of the working Registry
Old Jul 26, 2006 | 06:54 PM
BM08's Avatar
BM08
Think that programme does a backup(if you ask it to), but generally it wont delete things that will harm the workings of a pc
Old Jul 26, 2006 | 07:34 PM
dreamin's Avatar
dreamin
im back and after downloading the tweaking tool i am still in the same situation
Old Jul 26, 2006 | 07:50 PM
L33 BYT's Avatar
L33 BYT
Which is??
Share all.
Old Jul 26, 2006 | 07:58 PM
dreamin's Avatar
dreamin
L33 u have pm
Old Jul 26, 2006 | 09:18 PM
BM08's Avatar
BM08
ok but ill bet it came up with alot of problems? assuming you have never used a reg cleaner before
Old Jul 27, 2006 | 08:33 AM
DanRSturbo's Avatar
DanRSturbo
If photoshop's giving you jip, a simple uninstall, then restart of the computer, then reinstallation should do the trick
Old Jul 27, 2006 | 03:21 PM
dreamin's Avatar
dreamin
tried that dan n no go got a couple of things to try , thanks for trying to help tho
Old Aug 19, 2006 | 10:37 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
to enter the registry hit the start menu, select run then type regedit this will take you into the registry editor... which show you a working of the pc configuration. The registry editor has a search facility which you can use to look for specific registry keys such as photoshop's however there will be a large number of these.
As correctly stated messing up the registry can stop your PC from working.
Registry cleaners will not help you in this situation simply because the key is neither unrequired or damaged which means to remove it you have to do it by hand
What version of photoshop you got ?
If its the same as mine ill show you exactly where to look
Old Aug 20, 2006 | 10:19 PM
Thrush's Avatar
Thrush
Irritating c........
Fuck with the registry at your own risk - and it is a true risk.
Whilst I am no super-geek when it comes to PC's I am fairly confident and posess a pretty good array of knowledge on them when it comes to solving problems. I read a lot about something before I do it and gather as much intel as I can before doing something...
When I had a major virus buttfucking my system a year or so ago, I spent a long time sorting the registry out, modifying and removing, entry by entry, and all was going fine. Then one ill-descision later, my registry was fucked and it was re-installation time
Old Aug 21, 2006 | 10:57 AM
dreamin's Avatar
dreamin
cheers peeps im gonna leave it and get any of my photoshop needs donr by the guru's
Old Aug 21, 2006 | 11:02 AM
BM08's Avatar
BM08
Old Aug 23, 2006 | 08:35 PM
Turbocabbie
Top Cab !!
If you export your entire registry I will gladly tell you where the exact information is that you need to edit and tell you how to do it.
Doing a cambelt concerns me more personally than editing the registry
Old Aug 24, 2006 | 04:34 AM
SS1's Avatar
SS1
msconfig and regedit hard to work unless you know what your doing
below is a more information config program....
http://www.ccleaner.com/
it will ask you to make a back up copy first do it ...
and save it in your docs folder so you dont lose it .....
any problems after that just click on the blue cubes folder
old reg keys and programs are reinstalled
easy as pie
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
