Escort MK4 1.6 4 door CVH PROBLEMSS
sorry i havent posted for a while guys been busy!
got a couple of little issues with my mk4 heres my list hopefully you can help
which relay is the intermittent wiper relay as mine works when it wants to
i lowered my mk4 by 60mm is there anyway to counteract the amount of negative camber i have on the front wheels?
on cold start some days the auto choke works some days the choke doesnt work i have to sit and rev it.
when starting from warm usually the car wont start efficiently.
any idea where i can get a front right gearbox/engine mount from
thanks for your help
The intermittent wiper relay will usually be a tall red one, sometimes black, it will have something like wisch interval steurgerat written on it.
Lowered 60mm, only way to correct camber is with adjustable bottom arms, so the bottom of wheel is pulled in slightly, camber won't wear tyres though, toe does this.
As for the auto choke, what carb ?, give the linkages on the carb a good spray with GT85, nothing else, most likely a bit sticky.
Warm starting, check the ignition timing and CO.
Just try parts shops for the mount, sure QH will do one.
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
