Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
transit powerdrain problem
Old Feb 26, 2011 | 09:52 AM
whipsey's Avatar
whipsey
Default transit powerdrain problem
ive got an annoying problem with my n reg transit van where i have to keep disconnecting the battery overnight so it wont drain the alternator was replaced and is working fine.
It is fitted with a full alarm setup by a company called simba (cant really find much info about them) could this be a posible source of the drain?
Old Feb 26, 2011 | 10:01 AM
RichieST's Avatar
RichieST
Aftermarket alarms are notorious for causing battery drains. I'm presuming you have done simple checks like making sure things like interior lights/glovebox light etc are all going out.
If you disconnect the positive lead off the battery then connect a multimeter (set to amps) between the positive terminal on the battery and the wiring clamp you should be getting a high reading. Start pulling each fuse in turn until you see the reading drop. This should pinpoint which circuit is giving you the drain, so you can go from there.
Old Feb 26, 2011 | 10:10 AM
whipsey's Avatar
whipsey
i'll give that a go thanks
Old Feb 26, 2011 | 04:48 PM
Your first post is a bit confusing, even if the alternator is working fine it can still be causing a continual drain, so might be worth disconnecting this one night as well.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
DAZZER
Sep 30, 2015 08:43 PM
Russ Payne
Sep 25, 2015 08:29 PM
