Wheels and Tyres Wheels and Tyres for all Ford's
Wheel nuts OZ magnesium escort cos
Old 14-06-2014, 02:18 PM
ablc
ablc's Avatar
Default Wheel nuts OZ magnesium escort cos
Hello all,
i have OZ and i want to know what wheel nuts using for this 60° tappered or 60° tappered ghia with washer.
thank's you for advence
Old 14-06-2014, 02:25 PM
Maxwell
Irregular Poster
Maxwell's Avatar
I use the ghia/washer type nuts on mine
Old 14-06-2014, 03:35 PM
ablc
ablc's Avatar
sorry double post
Old 14-06-2014, 03:39 PM
ablc
ablc's Avatar
ok but lock at this pics with my nuts ghia
the washer does not applies all in the rim
So the 60° tappered seems to be a good choice not ?
Old 14-06-2014, 03:57 PM
Maxwell
Irregular Poster
Maxwell's Avatar
Tu non avez le jantes originale pour le escort. Tu avez le jantes "apres-marche" (tuning). il est possible le bien option, pour le 60° grad!! Non ghia!!
Pour "originale Ford", OZ fabrique le design, pour ford-ghia!! Le autre design pour tuning/apres-marche
Old 14-06-2014, 08:55 PM
andy escos
andy escos's Avatar
If you have genuine oz magnesium wheels they will be group A fitment so ghia nuts are no good you need groupA sleeve nuts which are available on ebay
Old 14-06-2014, 09:03 PM
andy escos
andy escos's Avatar
here you go this is the same nuts i use on my genuine oz mags
http://www.ebay.co.uk/itm/Group-4-wh...item2a35004df3
Old 15-06-2014, 06:57 AM
ablc
ablc's Avatar
yes it' guinine OZ Rallye but in 8x16 not take from Gr A but Gr N
i have guinine wheel stud whithout spacer.
i want purchase this tpi nut kit ;
http://www.thenutsandboltsshop.com/p...umCurrencyID=3
It's a good choise or stupide choise for my OZ ?
many thank's
Old 15-06-2014, 09:23 AM
andy escos
andy escos's Avatar
The nuts in your link are wrong you need m12x1.5mm for ford thread
Old 15-06-2014, 01:00 PM
ablc
ablc's Avatar
i am not sure that gr a nuts fits in my OZ because the nut it s too long and take place beetwin the stud and the insert not sure.
Old 15-06-2014, 02:20 PM
ablc
ablc's Avatar
sorry for flood.
to be to understand what i need
a nut with 60 ° tapper
a sleeve shank to the bore of holes of my rim and whose length is the thickness of my rims at the level of the insert
the sleeve is used to center the wheel?
those ebay links really seems too long sleeve
"Wolfrace type sleeve nut 41/64ths small bore"
this is seems to be good for me.
41/64ths small bore it's the bore to my insert ?
many thanks
JoeyBoyden
04-01-2024 02:36 PM
Carlbacciochi
24
30-06-2016 04:31 PM
FlashRS
14-09-2015 12:36 PM
rst-s1
23-08-2015 07:56 AM
RSMK4TURBO
19-08-2015 04:46 PM
Quick Reply: Wheel nuts OZ magnesium escort cos
