2.0 zetec turbo wont rev up
Old 02-08-2015, 12:47 PM
turbobill
turbobill's Avatar
Default 2.0 zetec turbo wont rev up
As above, just had my zetec turbo running after building it , its running omex 600 management,ecu has a base map at the moment, but it wont rev up, will just cut out , will only idle, any ideas to why? Ive checked for air leaks etc and carnt seem to find any, little bit stuck, cheers
Old 05-08-2015, 09:55 PM
Red_bull
Red_bull's Avatar
Guess your base map does not fit your layout. Try finding why it cuts out in the data of the omex. Guess its a stand alone?
If you tap the throttle inlet pressure should rise. Lambda should stay fine. Does the ecu send a longer signal to the injectors then pressure rises (for megasquirt this avaliable.
In a stand alone so much can be set wrong. Maybe you are only running on idle control and as soon as it goes into normal mode it cuts
Old 08-08-2015, 08:34 PM
studabear
studabear's Avatar
has it got a rev limiter set that might cut spark or fuel?
Old 09-08-2015, 05:21 PM
turbobill
turbobill's Avatar
Thanks for the replys, turned out the base map wasnt giving enough petrol so was cutting out, upped the petrol abit and it revs now, just need to try sort the poxy gearlinkages out and i can get it mapped, cheers
robnock
21
13-05-2019 05:29 PM
big_Rad
15-09-2017 09:36 AM
cossirob
29-08-2015 03:23 PM
Chopshop85
17-08-2015 06:38 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: 2.0 zetec turbo wont rev up
