Fiesta 1998 pats key problem
Hi
I hope somebody can help me before i go mad, last week i broke the chip in my only key, so i took a key,transponder pats, steering lock from a running car, and now it still wont start i found this on a website.
Code Problem Check
1 : 3 Key code not received is the key obscured, try again with different key, key may be damaged/faulty 1 : 4 Partial code only received is the key obscured, try again with different key, key may be damaged or faulty 1 : 5 Key not programmed to PATS Programme key 1 : 6 Faulty link between PATS and EEC v module check with FDS2000
I have 1-5 key not programmed to pats, how do i program this? it is weird because yesterday i took a work pats and key from a running car and when put on my car it dont work????
someone please help me
Code Problem Check
