3dr Cossie Not triggering Ign & Fuel pump relay
Having issues with 3dr cossie, fuel pump and ignition relays are not being triggered, will run if manually triggered but only for 20 seconds or so, will cut out sooner if throttle pedal pressed. Changed phase sensor crank sensor, phase is set correctly, alarm has been removed, would not start at all before. Tried different ECU and still no better. Car had been parked up for a while ran perfect before no nothing ?
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
