Installed K&N 57i now engine management light is on
recently bought my 2005 fiesta st150 and thought id let it breath a little better by installing a K&N 57i induction kit. installed correctly with the breather hose on and the cold feed pipe from the grill
Great results, seems to pull allot better now BUT the engine management light has came on a couple days after fitting it
Is it common for the new filter to bring the light on or is it just chance that something else has gone wrong at the same time ?
any reccommendations on what could bring the light on would be appreciated
3dr Cosworth owner
Maybe the oil that the filter came pre soaked with has covered the air flow meter causing it to illuminate the light. Quite common. Best off getting the codes read really to know for sure
Stu @ M Developments
41
21-08-2015 06:47 AM
