Sierra Cosworth Cam Caps
21-12-2012, 07:50 PM
Can someone tell me if there should be washers under the M8 nuts that tighten down on the cam caps.
21-12-2012, 10:21 PM
Live long and prosper!!
21-12-2012, 10:29 PM
Just have normal flat washers under mine.
Rich
22-12-2012, 08:19 AM
I didnt have washers or spring washers under mine! I think I will use washers and a bit of Loctite, unless someone tells me different. Thanks for your replies.
22-12-2012, 08:43 AM
22-12-2012, 10:29 AM
Quote:
Originally Posted by
Sonic Boom
Rich
I will have to check now ive a stock untouched head i will have a look
22-12-2012, 03:05 PM
costina
I would appreciate that, thanks.
22-12-2012, 03:24 PM
flat washers under mine. 1 head was untouched and the other one was a modified one both had the flat washers.
22-12-2012, 05:27 PM
Just checked flat washers torque setting is 18 to 21nm
22-12-2012, 05:51 PM
costina
Thanks for taking the time to help me. Merry Xmas
charliecosworth
19-08-2015 02:00 PM
cossie4x4
14-08-2015 06:29 PM
155lee
14-08-2015 11:21 AM
Roosie
13-08-2015 07:40 PM
dal3door
13-08-2015 06:55 AM
