Spray painting over Chrome Rims
I am pretty good with a spray can but have never tried painting over Chrome, my wheels look a lot like these, I will be re spraying the spokes black and the rim which is Chrome in white. Any of you had any experience spraying Chrome???? any tips/help I would appreciate. thanks
![](http://i511.photobucket.com/albums/s357/rsvmad1/k2raven2095sslipblk.jpg)
are you sure its chrome and not mirror polished alloy,if its alloy then just key the rim with some 180 grit and etch primer it,if its chrome then its much more involved and will need to be more agressively rubbed down with at least 80 grit as its a much more harder material then you need to prime with a good qaulity very high build primer to fill the scratches but it will be prone to chipping around the edge,ive painted lots of chrome before using this method and been succesful but not done wheels before,just be aware that unless you have the rims acid dipped or sand blasted back to bare metal its not going to be very permanent,hope this helps,
yeah get rid of all the lifted chrome first then rub down as much as you can,its a very time consuming process but the more its done the better it will be also the coarser the paper the deeper the scratches which will result in a better chance for the primer to adhere to,i would suggest a high build 2k primer as anything you can get in an aerosol wont fill the scratches.
if you do get them blasted its probably best to just get the outer rim done cause the high pressure might damage the edges of the spokes as they look quite thin.
Thanks mate. the first one I thought looked good but there was a couple of little bits that lifted , so the second one I just finished looks mint I took the time to prepare it properly (back to bare metal, with sand paper) took me all day to prep lol..
Ill do the same on the other two and depending how fed up I am I might do the first one again, but not that It "needs" doing it still looks sweet im just picky lol
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
