Found oil leak! MORE questions raised.
ZVH sold =(
The oil leak on my ZVH was coming from the rear of the block where someone had drilled a hole for the oil breather and glued in some sort of old hose fitting, which obviously didn't hold.
My question is what do I do to secure a fitting on there properly as there is no thread? The hole is 11mm in diameter, what size tap would I need to use to put a thread in this? I don't fancy drilling the hole to 18mm due to it being in situ and don't want loads of swarf in my block. Any help is much appreciated, I WILL get this car on the road!!!
Mitch
Mitch
I would use a tapered fitting, then just bang it in there, if you can't find a suitable fitting pm me and I'll machine one for you if given the dimensions etc.
ZVH sold =(
Thanks Tabetha, I think I will remove the sump and do it properly.
Is removing the sump on the ZVH a straight forward job or a mare. I know I will need to remove the starter and exhaust but how do I get to the end bolts at the gearbox end?
Thanks again.
Mitch.
Thanks again.
Mitch.
tokey smurbo
there are no bolts on the gearbox end of the sump,like there are on cvh engines, sump will come offf pretty easy mate done mine in the car easy enough,
hope this helps
steve
hope this helps
steve
