XR4i Full Beam will not turn off!
XR4i Full Beam will not turn off! I used the car yesterday night, and all was O.K. The lights worked fine, until I put the full beam on. As another car approached I switched them back to dipped, the two inner spots go off, but the main lamps stay on full beam. These stay on even if I turn the lights off. In fact the only way to reset them is to turn the engine off and restart, then it's back to square one.
I recently fitted a second hand front left light so suspect this may be the culprit, but cannot fathom why. It worked fine originally.
Any ideas?
Mike
Any ideas?
Mike
This is odd, as the main beam feed comes from the same source for the spots as the main h/light.
Are you using additional relays at all, as it sounds like a sensitive relay being fed, I would clean up the earths anyway, these always cause trouble, best thing is to put a new earth wire direct onto the spade terminal on the inner spot that you can see when removing the little cover, then straight out the rear cover to battery, will improve no end, as would rewiring the bulbs as well.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
