| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
![]() BANNED |
HT leads can certainly do this yes, will normally be worse when wet weather, or dewy morning.
The KERR NELSON leads work particularly well on these, used these myself, you didn't use bosch plugs did you ? tabetha |
#3 |
Hi
Yeah i replaced the plugs with the Bosch super 4's. On the previous service i put the Bosch plugs in and there were fine. The lumpyness has only started happening since the weather dropped a little colder. Think ill replace the HT leads and hope it solves the issue. Lee |
#4 |
![]() BANNED |
I would replace the plugs first with geniune ford or NGK/Champion ones.
I have seen so many of these engines with bosch plugs leaking, look around the ceramic, and see if there are streak marks up the porcelain, if there are bin them, I've had it myself 2 plugs out of 4 within 100 miles started leaking. tabetha |
#5 |
Thanks for the advice. Ill pop my old motorcraft ones in see if the symptoms go away, if so ill go get some new ones.
cheers Lee |
#6 |
![]() BANNED |
No probs LEE, hope you get it sorted and welcome to the site.
tabetha |
#7 |
Old plugs back in and still no difference. There is a whistling when revved sounds like coming from egr is this normal? or is it a leak that could be causing the issue. Also noticed when replaced the plugs that it was running a little rich, im guessing this could be caused by a leak?
Cheers Lee |
#8 |
try cylinder head temp switch it is where the plugs are should be another two wire loom going into the plug holes sounds like thats your problem apart from that you will need to get it on ids to check live data
#9 |
After replacing the plugs the engine light went out after a day or two!!! Has been running good since still a little hesitant when cold but not sure if thats vibration from exhaust will have to go get this looked at. Then last night on way home from friends engine light back on!!! Darn it!! Time to get the WD40 out and see if i can find any air leaks. Ive been told i should hear a change in engine noise when sprayed on a pipe with a leak.
Will let you all know what i find so hopefully this will help anyone with similar issues. Lee |
#10 |
you might find that you need a new cat. i had a focus 2.0 esp that developed a misfire and the engine light came on. i cleared the fault and changed the spark plugs. the misfire was cured but couple of days later the light came back on. plugged it back in at it basically told me the cat was shagged because of the fuel that had gone through the cat from the misfire.
__________________
boost, boost, more boost. BANG! |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Will ford focus st170 alloys fit my focus mk1 2003 1.6 zetec? | gazloveslou | General Car Related Discussion. | 2 | 21-02-2009 09:57 PM |
| Focus 1.6 Estate, Zetec or not Zetec? | Onetime_Fiesta_Owner | General Car Related Discussion. | 5 | 28-08-2008 02:47 PM |
| Can i fit a Zetec-E head to a focus CGI Zetec R Block | Dub-Se7en | Technical help Q & A | 0 | 02-02-2006 10:00 PM |
| 1.8 zetec runnin a bit lumpy | sedan man | Technical help Q & A | 6 | 09-11-2005 09:13 PM |
| Lumpy | Anonymous | Ford Escort RS Cosworth | 4 | 18-02-2004 07:29 PM |
