rs 1600i cutting out
hi all just woundering if any body could help me with this problem i have.
from the start the runs and drives perfect apart from when im coming to a stop the car cuts out .basically when the car is runnin and i put my foot on the brake it cuts out.ive replaced all hoses and checked to see if they were in the right place which they are.
Back in business
iv got a 16i myself with a v,similar fault check the fueling out!They are fitted with a decelaration conponent [ecconomy lights on instrument pack]its possibly the component that controls them at fault.
If it's running lean, applying the brakes can make a difference due to servo, but is it at the correct idle rpm to start with, could just tweak the mix richer a touch will often help, but if valve knackered on servo pipe this will also cause it as it introduces a air leak when brakes are applied.
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
chris m1
07-09-2015 08:02 PM
