how do i identify what ecu + chip my 2wd saffy is running ?????
just bought my 1st saffy and been told its stage 3 etc etc , i bought it with a blown engine and am currently rebuilding her but am just finding my feet with it and would appreciate help with identifying the ecu + chip for starters and im sure ill be needing loads more help and advice in the next few months ,
cheers, Danny
cheers, Danny
For the ecu see the pictures at:
http://www.bigturbo.co.uk/main1.htm
Is there anything written on the ecu or the label on the chip?
just looked at the link and i think its a level 1 ecu , it has a yellow mixture screw and the transistors are screwed down , are these ecu's any good ?? if im looking at the right thing there is a sticker on the chip saying (sierra y/s 2 803/320) and hand written it says roy's and 3 on the sticker too ??
I agree, 803 injectors and probably a 3-bar map sensor from an unknown source.
The only problem with a L1 ecu is that you can't have closed-loop lambda control and other fun things like launch-control and ALS.
thanks for that , ill prob run it for a bit whilst i run the engine in after the rebuild and then might start playing about a bit more
cheeRS , Danny
cheeRS , Danny
big_Rad
15-09-2017 09:36 AM
FlashRS
13
31-08-2015 06:02 PM
