How to remove a fuel cap that's stuck?
Old 08-07-2009, 06:19 AM
J9BBY
J9BBY's Avatar
Default How to remove a fuel cap that's stuck?
My Mk3 Fiestas fuel cap has stuck in place. The key won't turn in the lock and therefore i can't fill it with fuel.
Any suggestions on how to get the bloody thing off? I've considered drilling down through where the key goes but unsure if this will actually help me. Any ideas?
Thanks,
Pete.
Old 08-07-2009, 07:55 PM
frsjon
frsjon's Avatar
hi mate....there a pain in the arse when they do that... the only real way is the key but be prepared for the metal part of the key to twist round in the plastic part..best use a old key really... once you do get it off take the clip off the bottom of the cap ,strip it all down and lube it all up...will be fine after that...
Old 08-07-2009, 08:23 PM
JonathanJ
JonathanJ's Avatar
Had this in the early days of Fiesta production , best advice is soak in with WD40 or the like then slowly work the key in the lock until it frees up .
Old 09-07-2009, 06:25 AM
J9BBY
J9BBY's Avatar
Cheers, i'll give that a bash tonight. Hopefully the key won't snap!
manuel boeckx
13
03-10-2015 02:29 PM
muffster
13
03-09-2015 09:40 PM
29-08-2015 08:16 PM
ekjim
17-08-2015 08:57 PM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: How to remove a fuel cap that's stuck?
